The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
I´m planning to dedome the LED.
Should I choose the CW Version?
This is a 6500K 1A?
Is this LED better for warmer (not greener) Tint after dedoming / shaving:
http://kaidomain.com/Cree-XHP70_2-P2-1A-White-6000K-LED-Emitter?search=xhp70.2
Thanks
That is pretty much what comes in the stock light.
I noticed the new emitter info was not in post #4. I updated it.
CW is 6500K P2 1A.
NW is 5000k P2 3C
TA says he would go with the CW for slicing the dome off over the NW. It’s the better looking of the two choices. If you can reflow leds then it might be best to shop around and get something that better suits you. If you like NW, maybe a 2A or 2D would be better?
I’m sure TA will give more details tomorrow.
This I’m not sure. Maybe someone who has ordered a CW light can say. Did you guys get just an email with the order instructions or a PM?
I got an email with instructions and a link, but that was for the CW version, not NW.
Okay, I’m sure it will be the same with the NW and the conversion kits.
Are 2A oder 2D (5700K) available with Binning P2?
Not found one till now.
I don’t know, I have not looked.
Here is a P2 5700K but I don’t know the tint code. Could be A, B, C or D.
I recently ordered one of these and should be receiving it any day now.
What’s the exact package of our XHP70.2s we have in our GT70 ?
(d’thing is: many suppliers ask you to select a package first)
What do you mean by “package”? I’m not familiar with the term. Can you give me an exampke?
This is what TA posted earlier: 5000k XHP70B-3C-P2
Maybe he can answer later today.
I second that thought. The BLF Q8 5000 - by far is the best bang for the buck ($40-$49) for everyday carry, and power consumption. You will not be disappointed. I personally have 6 of them.
First off I am far from clear on exactly what has gone down with your order but my best guess is as follows:
Where are you located? I think that the shipped fee they refer to is due to your location. Some locations need an extra $20 or $40 for shipping. That would explain $20 of the extra $28 and sadly no, this is not refundable. Only the $2 overcharge on the price is refundable if you request it.
I am also guessing that the bag and cap were not included with the first order, which is why a second was needed. That would seem to mean that you need a $8 refund, not $6. So that is odd.
Finally far as them not being shipped together, sadly I can’t say I am surprised, nor can I really blame them. Having had to deal with mass orders like them many times personally, it is oh so very easy to not realize there are 2 separate orders going to the same address ad thus waste money shipping 2 separate orders.
Now the bag and cap should of been sent separately, that I can’t really explain.
I would suggest that you contact Neal, he is the one that actually sourced the bags and caps, it is possible he still has some available and he could sort it out on the back end somehow. I will contact him and give him a heads up.
We have not seen a stock CW dedomed LED yet to know what the final tint would look like, so it is impossible to say if it would be better or worse then the one from KD.
That one from KD should work ok though.
As Jason said, any A or D tint LED should work for dedoming. At least as good as we can get.
The term “package” defines the design or footprint of an IC. (size, housing type, connections (pads, pins), etc…)
LED Packages
So what I mean is: Does a XHP70.2 always look exactly the same, with the same electrical requirements the same pad position, size, etc….? So I can buy any XHP70.2, and it will always fit……
I think this is the case, but I am not 100% sure….
Yes, they are all the same. You can configure to run them at 6V or 12V depending on how the PCB is configured, but the LEDs all have the same pad configuration and package size for the 70.2.
Yep, what he said. I do not know if there is a standard package name for the XHP70.2 footprint though. You could try looking for something like 7070 6v or 12v but I kinda doubt you will find anything.
Okay, I was over thinking it. It’s a simple thing. They usually go by the dimensions of the emitter base.
All 70 and 70.2 are 7mm by 7mm aka 7070.
All XML, XML2, SST-40, 50 and 50.2 are 5mm by 5mm aka 5050
All XHP35, XHP35.2, XPG, XPG2, XPG3, XPL are 3.45 by 3.45, but we call it 3.5 x 3.5 aka 3535.
Nichia 219 and 319 are actual 3535.
The new version Luxeon V are an odd duck at 4040.
So it’s just a matter of matching the package to the pads on the mcpcb.
With the 3535 they just have 2 electrical pads. They can run a 3v xpl, etc… or a 12v xhp35 because it’s 4 dies are wired in series. So you send 3v to an xpl and 12v to a xhp35.
Now the 5050 and 7070 are a bit tricky as you can run them at either 6v or 12v. This is determined by the mcpcb and it’s pad arraignment. You need the right mcpcb for your voltage needs on the 5050 and 7070.
Hopefully that’s enough info for you. We’ve talked extensively about mcpcb pads and the different types of voltage setups back in the GT thread and elsewhere. It helps to use pictures to explain that.
Kingjohn, if you want to keep a list of all the package and die sizes of the most common emitters, just take a screenshot of this LIST to keep with you. This is what I do so that I can quickly see all the details that I need.
I see they’ve added new emitters and it now has links. Cool.
HOT OFF THE HAZG PRESS
Next Update: September 11, 2018
The final set of emails for the neutral white GT70 and conversion kits will be going out next week. So if you want in, now is the time to sign up. The google form will be disabled when the emails go out.
At that point the only way to get in will be to PM me or Jason for the details manually.
I didn’t get the email for the CW conversion kit. I’m signed up as per the log above. Can someone please send me the code?
Thanks
