Sofirn Q8 group buy (gb closed, but try PM to Sofirn for discount)
It’s on its way
Most recent update
Arrived awaiting clearance (Inbound)
SYDNEY NSW
I purchased a 2nd set of VTC6 in anticipation of delivery. My 1st set of VTC6 for BLF Q8 are charged and ready for side by side comparison.
Looks like you’ll be the second person here to receive the Sofirn Q8. :smiley:
My order, as of last tracking update yesterday, is still in GuangZhou, “air transport” (ie. just about to leave China).
Regarding the Sofirn Q8, did they still use NarsilM v1.0? Or have they updated to at least NarsilM v1.2?
Strobe modes (not that I use them much though) are a lot more difficult to use on NarsilM v1.0.
They updated it to V1.2.
First it’s gotta get processed and then get to Melbourne. Could be another week :frowning: My 2nd BLF A6 arrived with Australia Post awaiting clearance in melb on 5th Sept but light only arrived yesterday.
Thanks, I should’ve read the OP straight through before posting. I want to buy from Amazon in the US.
djozz, do you have measurement of standby current? Thanks.
I recently received some Q8 drivers. They had a tantalum capacitor stacked on top of what appeared to be the original stock capacitor at C2. C2 is attached to the trace that powers the MCU. That might account for the new behavior you noted. I didn't get a chance to see how the drivers behaved because I modded them for 2S and 4S cells and also reflashed their MCU's before I even used them.
It should be the same as the original Q8.
135 micro amps switch led on
22 micro amps switch led off
Thanks.
I was thinking the driver might be different from BLF Q8.
The only difference should be the newer firmware. That should not effect the parasitic drain. It may have an added capacitor to make it more bump resistant.
Maybe someone can double check that the parasitic drain hasn’t increased. Only a couple people have them so far.
If anyone wants to check, here is how you do it.
You can temporarily deactivate the switch light by turning it on then ramp up or down and turn the light off very quickly.
YMMV, but I’ve seen meters show different values when the probes are inverted as they are in that picture. It can’t be an inverse drain, so of course the probes are on the wrong ends.
1 x Solfirn Q8 via Ali
The Sofirn Q8 is in the Sofirn store on Amazon!
Where is my code?
Correction!!! that is the BLF Q8 :frowning:
Amazon US for me, please!
2 x Sofirn Q8 via AliExpress please
In terms of different functionality,or how functionality is implemented, firmware definitely can affect parasitic drain, I don’t know anything about the difference in this case, you are likely correct.
In this case we are talking about NarsilM v1.0 to v1.2. There are only small changes in the code. Whether it takes 6 years to drain or 11 or 2 makes no difference to most people. If your going to store the light for long periods it’s always best to turn the battery tube to cut all power.
Maybe someone will report back the drain they measure.
Asked by Aliexpres and on the way, I hope to have her soon at home, thanks for the help. :smiley:
Maybe because it’s a direct drive light and the measured output actually varies a lot depending on batteries and a lot of other factors.
CW also tends to measure higher than NW. So maybe they’re getting very similar measurements?
You lose trust way too easy. Only a handful of people have actually received it so far so we don’t really know if there’s a problem or not. It may be a simple fix. It’s way too early to tell.
I measured the sample Sofirn Q8, not exactly 5000 lumen but close enough IMO, see the OP for details, should be pretty accurate.
