No momentary on, it will 1/2 press momentary off though, not sure if they changed the tail switch…, but it has good output and decent tint for CW, and seems like a good mix of flood/throw(was very misty out so I can’t accurately assess throwing ability until I get a clear day,) it’s a little bigger in diameter then other lights in this class but overall a really good deal for under $15. It would be better if they had flared out the arms on pocket clip though, it comes unattached and seems like it might scratch light when trying to install.
On amazon home page, near the top is a link for “todays deals”
After you open that then apply filters on the left column, I use “home improvement, Sports and outdoors, Power and hand tools”, then apply the lightning deal filter below that section, then you can go through the pages and click watch deal under an item you are interested in, do this stuff on the website, on your phone you can enable notifications in amazon app and it will remind you when they start
Thanks. I got his one, pretty good light but pretty big… Later I found that the NW version is also available and its a buck cheaper as well, wish I saw that before.
Snagged the NW a couple days ago on Amazon for $14.99 and the 20% coupon. Ended up costing $12.90 here in WA after tax. I’ve bought probably 6 or 8 of the F1 lights and this is least I’ve paid so far. Good deal.
Grab it as a gift for a friend. He has all kinds of different emitters. I just knew he liked them and wouldn’t buy one himself so I figured I would further enable his addiction.
Picked up one of these USB power supply—It has an LCD screen showing voltage—amp draw and capacity — only $7
I’m very surprised the output exceeds it’s rating of 2.4 amp @ 5v—the LCD screen matches my UM25C tester for voltage and amp output but the capacity runs about 10% high
