This one’s output seems much lower. There’s also a lot less of any one color leds.
Oh, it’s way bigger as well. So that helps reduce heat.
and I thought it was determined that the T1 didnt have heat issues unless using a defective battery …. did I miss something?
Yes, even a ‘bad’ cell (high IR, etc.) will heat up substantially even when charged.
It doesn’t have heating problems.
That’s pretty much the case it seems. It can heat a battery to around 50°C to 55°C. Most cells have an operating range of up to 60°C or 70°C depending on the cell.
I worded that badly.
It is still safe and does not appear to go over the limits of any of the components.
It does get unnecessarily hot due to a bad heat path though. I should of asked if this lantern has a better heat path.
Look what I did… TCLO!
After another fishing trip last night where my T1 was half dead before even arriving at the secrete fishing spot cause it got turned on high in my bag I was determined to get TCLO working without use of a paper disk and I accomplished it with ~8” of Teflon pipe tape!
That’s neat…. but I wonder how many screw/unscrew cycles before it needs to be redone?
Even if it needs redone once a month it’s better than the other options [none] and a lifetime supply costs 99¢…
any update on the next batch?
word
Previous sale rep left the company last month. I have yet to receive an answer from his successor.
I have 2 and like them, until one started acting up. It turned on by itself and no longer powers off. Neither are used much, couple hours each max total.
hmmm…. I have 3 T1s …… 2 of them have been on 24/7(low/warm) since the first week of Aug except for charging every couple of weeks. No problems here.
Nice one Cereal_killer, thanks for sharing!! . :+1:
i read this treads in every log in. and wish the T1 will come on sale again.
I would maybe wait for version 2.0. This one could use a few tweaks to make it better.
sound’s greats
delete:i read this treads in every log in. and wish the T1 will come on sale again.
Were there any information about this version 2.0 ?
I am interested in at least 2pcs
JasonWW: delete:i read this treads in every log in. and wish the T1 will come on sale again.
No info yet.
