Wanting to buy a 20000mah+ powerbank with removable cells and 4 Amp charging
16 posts / 0 new
InvisibleRasta
Last seen: 3 years 2 months ago
hello guys as title says i want to buy a powerbank that i can remove the cells when they die. I am looking for something around the 20000mah to 50000mah.
I will be travelling alot and i need to charge my 2 phones and a dslr camera. I dont mind if it has only 2 exit as long as they are fast charge.
Id be gratefull if somone can help me figuring out what to get
thank you
mrheosuper
i just bought a powerbank with 8*18650 slots and DC output for charging high voltage device like my laptop
it’s from china
https://item.taobao.com/item.htm?spm=a230r.1.14.29.af7b6ac6aOm1oD&id=540...
i don’t know its name but the spec is good
Forgot my pen
bmengineer
bmengineer's picture
Last seen: 10 months 1 week ago
Depending on your budget, the Omnicharge Omni Ultimate that maukka shared may be of interest.
Find all my reviews of flashlights and more gear at www.bmengineer.com
HKJ
HKJ's picture
Last seen: 1 day 18 hours ago
That means 6 or more replaceable cells, I am not sure that is very practical.
Up to four cells is fine to replace, but anything more and I am not sure I would like to replace them (An extra power bank it not that much overhead, compared to a spare set of batteries in that size).
InvisibleRasta
i have at home a diy powerbank chip that is not too bad but i wanted to buy some 18650’s and the price of them to get 20000mah is higher than buying the new
Anker PowerCore II 20000mah so i am not sure and its setting me off
InvisibleRasta
on amazon 4x Samsung INR18650 – 35E are 25 euro.. is it worth it?
mrheosuper
well, it’s up to you, if you can take a risk and can ship from china, a single 18650 34E will cost about 3 or 4 dollar
Forgot my pen
InvisibleRasta
do you think that doing Diy would be cheaper? what is a good chip for diy powerbank?
InvisibleRasta
i can also consider other battery technology types
Aleister
Aleister's picture
I would suggest Xiaomi 2C (20000Mah) at ~25 euros and forget about removable batteries.
The alternative is to build a 20000Mah powerbank with, for example, 6*NCR18650B and a DIY powerbank case. It will cost you ~30 euros just for the batteries + at least 10 euros for a low to medium quality DIY case and, still, 2C will be better, cheaper and it will cost less to replace than 6*18650 when batteries die.
Get a 2C or get 2*2C if you need more capacity.
http://budgetlightforum.com/node/44933
http://budgetlightforum.com/node/55221
Let a flooder be my wife and a thrower be my mistress
Jhicks2018
Last seen: 1 year 1 month ago
Might consider a solar charged power cell but 50,000 mili amp hours is a ton. A good 18650 is only putting out 3000 to 4000 mili amp hours so you need 16 cells at 5$ a piece, that’s 80$ for batteries and it will take a long time to recharge 16 batteries and the cost of the chargers. I see some power banks on ebay claiming to be 50,000 mili amp hours https://www.ebay.com/i/222504844817?chn=ps&var=521349944067 this is listed for 15.99 there is no way this is 50,000 mili amps. Here is a video of a guy making one with 2,200 mili amp hour 18650,s and it is much bigger that that battery pack on ebay. https://www.youtube.com/watch?v=PQmwDmwYztk. Then this guy makes a 40,000 mili amp hour battery out of 3-6800 mah =20,400 + 3-1500 mah =4500 so 20,400 + 4500 =24,900 https://www.youtube.com/watch?v=Glc0pk_X4Hg not even close to the 40,000 claim. A samsung S8+has a 3800 mah I phone s8+2,900 mah and a I pad air laptop battery is 7,150 mah. You are most likely getting a 20,000 mah battery and you will only be able to use to 2/3 of that avaible power not sure the phone and computer but that would help to determine the mah of the batteries in those devices to see what you really need my thought is with a 20000mah battery you could charge each phone and the laptop not sure the capacity of the camera battery but figure that information out first to determine your overall MAH then see what size you need . Here is a good video that explains the actual use you will get from various battery chargers https://www.androidauthority.com/portable-power-bank-capacities-gary-exp.... Hope some of this helps you can build a 50,000 mah battery but it will cost you a bit at least with a solar charger you can recharge your batteries on the go when you are not using your power bank.
John Hicks
A_M_K
A_M_K's picture
Last seen: 7 hours 47 min ago
You are looking for the ultimate DIY power bank? I think this is it! – https://detail.1688.com/offer/522199323051.html?spm=a2615.2177701.568089...
This beast can output over 100W of power.
Phlogiston
Phlogiston's picture
Last seen: 2 months 5 days ago
Are you planning to carry this thing on a plane at some point?
You can’t carry a battery pack or power bank of more than 100Wh on a plane, unless you get prior approval from the airline. For a standard Li-Ion equipped USB power bank, that’s in the range of 25000mAh to 28000mAh, depending on the nominal voltage of your cells.
jerm03
Last seen: 1 day 11 hours ago
For me a 20,000 mAh power bank is too large, and Iwould prefer 2ea 10,000 mAh such as Xiamoi. I recently bought a 20,000mAh power bank to see if I liked it, and I did not. I gave it to my daughter.
I have concluded it is also cheaper to get a good “factory” uit than to buy a quality DIY unit and then quality batteries.
Jerry
will34
will34's picture
Last seen: 3 hours 45 min ago
The worst thing you can carry for traveling is dead weight, get yourself a compact and efficient powerbank like the xiaomi 2C or 10,000mah, a good set of cables and fast charger.
Powerbank with removable cells are often inefficient, takes more weight and volume, and loose cells makes it not as safe.
angerdan
angerdan's picture
Last seen: 8 hours 19 min ago
it’s from china
You can go for the 8-cell version of the YZXStudio Powerbank:
http://budgetlightforum.com/node/48561
Or get 2x Soshine E3S-QC with 30W output:
http://www.soshine.com.cn/a709.aspx
