Interested.
[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
subscribed
Interested
interested
Sneak peak for PL47 prototypes. FF is still fine-tuning the final design. Expect a champagne color to match with your ROT66!
©freeme
Interested.
Interested
I didn’t realize this was supposed to be a headlamp/angle light. Hmm…
You might want to mention this little detail in the OP.
Looks like Lumzoo with a milled head.
For now I know that the driver uses FET + 3 AMCs, similar to D4S
one switch LED controlled by MCU
Aux board controlled by MCU
The aux board has a build in low battery warning and LVP
The standby drain of the voltage detect chip and LDO is about 0.05mA
The board will have a 3x3mm SMD trimmer to set the outer LEDs brightness as the user likes
LED colors are not decided yet, in theory it can have each LED with a different color
the low battery and LVP voltages are not determined yet
if the boards detects low battery voltage the outer LEDs shut down and inner LEDs light up, likely inner will be red
The technology of the Aux board is shown here
I’m in
Are we expecting protected cells to fit in this light?
I’m in
Can I request that a strong magnet be in the tailcap? Or at least give us the option for those that don’t want it. But it’s very useful in my eyes. Thank you!
More photos from Firflies’ Facebook. The size much smaller than I thought.
Size: 88mm x 28mmx25mm
Net weight:72g
yes please
That’s kinda cool that they pushed forward the emitters and optics so the battery could tuck behind it all to make it overall shorter than a Zebralight 18650 headlamp, even though it uses a 21700.
+1 for the magnet option.
Fireflies PL47 equipped with strong magnet tailcap.
Holy cow, can’t believe FF got it down to such a compact size for a 21700 light. :+1: This is how I imagined an Emisar headlamp would look like.
