Well, on the fidget spinner front, my friend bought this Atesson for me so it was free to me, then I spent $27 on Tungsten weights and bought a top of the line premium grade ceramic hybrid bearing for a ludicrous $43! The tungsten weights are supposed to net 3x longer run times, the bearing, well, don’t know. Better be good for the price, right?
I was just gonna tell my buddy about these fantastic run times I’m getting and not say anything about the expense I’ve gone to in order to get there, but I couldn’t bring myself to do it. I told him about the upgrade parts that should start arriving tomorrow. lol
Those look really nice. I may order them. I already have several mid range headphones and a couple of headphones amps connected to different sources. I’ve been into audio since the 1960’s. This is what I have at the present time:
Headphones
Denon D2000
Beyer Dynamics DT770 Pro 250 ohm
Tascam TH-02
Sony MDR-V6
Sennheiser PX100
My Atesson spinner in stock form was getting up towards an 8 minute spin on a flat surface. I bought a very high end custom ordered Hybrid Ceramic bearing and Tungsten weights for it and have achieved a vertical spin of 15:10.44. Yes, that’s 15 minutes, 10.44 seconds!
Edit: I would be remiss to leave out some specifics, my friend sent me the Atesson spinner that he bought on Amazon for some $15. I then spent $43 for the new bearing and $26 for the weights, in an effort to best his 10 minute spin time. So yeah, while I did best him by a significant margin…it cost me! (SWMBO does not know of this additional incurred cost…. shhhhhh! )
NO lube! Oil on the balls inside the bearing will create drag and slow it down. The Atesson uses SS balls in a chromium steel race (51200 I presume) and also has a steel cage that is double sided. It is possible to just wash it out with detergent and hot water and then blow out the remaining water after a good rinse, but it’s imperative it get’s dried good or there could be a possibility of some rust developing.
Dry works best for spinners. Especially ceramic ball spinners. I get that direct from an engineer at a high end bearing company in CA. (yes, I called them)
Got my $6.99 spinner from Amazon. Not impressed. The bearing has play and it only spins for about 90 seconds. I ended up giving it to my neighbors 5 year old son. He loves it.
Those outer bearings are very light weight, replace those with brass weights or tungsten, changes the game completely.
The brass weights in the $15 Atesson are about 27 grams each, the tungsten aftermarket weights are 45 grams each. Either way, a LOT heavier than those 608 bearings…
Edit: Pics
The brass weights that were in the $15 Atesson spinner…
The new components, high end hybrid ceramic bearing on the left of the original SS bearing, with the Tungsten weights not pressed in yet…
Ordered a Parasound Zpre3 preamplifier from Audio Advisor. I have the matching power amp. It’s going to replace my old non-remote controlled Parasound PHP-850 in my bedroom system.
My new PreAmp came yesterday. It’s on the right. The matching Poweramp which I purchased 15 years ago has a rack mount front panel which they don’t offer any more as standard equipment. Oh well. Not that it matters for my use. So far it’s been impressive driving my B&W 603 series 3 loudspeakers in my AV bedroom system.
