I didn’t want to change a bit in this light. I’m happy with it as it is.
I created the survey just for information purpose only. It will be Sofirn decision if and what they gonna do anything with this information.
You started a poll in this thread which is about this group buy light without mentioning that you apparently are targeting the results for a future batch, you can not blame me for thinking that the aim was the current batch so I responded like I did.
Of course I do not blame you and I would react probably the same
I should mention about the survey that this is for Sofirn information only, not to change this light.
Hopefully they will consider results for future batch.
Sorry for confusion I made.
Yes. I have the high CRI version. Not sure of exact output; probably 5 lumens. The best reading light I have ever seen. Mine doesn’t look quite that nice though.
Yes, the Sapphire and the Sofirn are both AAA, and both use 60 degree Yuji, although the Sapphire may be Longer due to the tail design.
here is a visual aide (may not be to scale) showing the Sofirn when it gets Turned On:
I know BLF has a habit of getting off topic, but if you want to ogle over women there’s plenty of more suitable places in the web for that. Let’s try to keep this thread somewhat on topic.
I especially like AAA flashlights because they can always be carried and used batteries that can be purchased anywhere.
But I especially like the color camo: as some special edition of the Sunwayman R01A and the Arc AAA.
Maybe Sofirn could launch a limited run of its new model AAA 5mm led, in camo color as the R01A and the Arc AAA, and feed them with a slightly larger current, about 50mA in led, that is, about 15 or 20 lumens . Of course, with the corresponding surcharge, which I would gladly pay.
