I can probably figure it out myself (trained in college) once I open it to flash it, waiting for my soic clip, but before taking it apart I was wondering if there are any spare outputs on the AVR microcontroller.
You don’t need a circuit diagram to flash the part. You just need to be able to identify pin 1 on the IC, and how to wire up the flashing interface of your choice. I can’t answer the question definitively about spare pins, other than I know pin 1 is not used in circuit, in order to make it easier to flash. I suspect there is another unused pin, but my bare board is at work right now, otherwise I would inspect it to see. Based on the picture in this post, I believe pin 7 in unused. The picture should help you find pin 1 also.
On the D4, pin 3 is also available, and even has a solder pad connected to it. This was set aside to control aux LEDs or a button LED, but it wasn’t used. It is used on the D4S though.
I don’t know why Hank changed the colors available. I think he said the green was very difficult to get right though.
Does the fully-configurable beacon allow you to independently set on-time as well as repetition rate? The biggest complaint I have with my D4 beacon is that it is really just a “blinker”. A true beacon should have a very short on-time so that it can be full brightness yet still preserve battery life.
Nope, it’s 0.5s on, (N - 0.5)s off. But if you want to change the duty cycle, it should be very easy to do by changing one or two lines of code. It’s open-source.
It’s tempting, especially after reading through the 5K or so posts in this thread and seeing that many users are successfully modifying their code. But it would be a first effort for me, and I’m reluctant to risk one of my favorite toys in a learning exercise. And I remember someone (was it you?) may have mentioned that certain missteps result in an inoperable and unrecoverable (without special hardware) brick.
The D4S seems to be slightly more mod-friendly, and I’m already tempted to buy one of those. And I seem to remember reading someone’s (you again?) notion that maybe a beginner’s hardware/software programming kit could be offered as a turnkey “get started” package. I’m more likely to get my feet wet that way, then look at the D4 after gaining some confidence.
I haven’t managed to get any stores to carry a starter kit yet, but I still hope that can happen sometime. One of the main steps right now is finding a way to manufacture Lexel’s flashing key, and getting more brands to use it on their drivers.
However, it’d also be nice to have a kit based on a more common chip clip. (SOIC8 clip)
I’ve read hundreds of posts and finally successfully flashed. Here is a condensed version of the hardware and software you would need if running a Windows computer (I use Windows 10)…enjoy!
I had some trouble figuring out exactly what to buy, but I figured it out after reading all the posts for months. Just get those three things I linked below for hardware.
I bought this: https://www.amazon.com/gp/product/B00AX4WQ00/ref=oh_aui_detailpage_o02_s…
and these:
ya…cheaper from china…but not by much, and I prefer Amazon reliable quick ship. Not worth saving 3 or 4$ ordering from china and waiting a month.
Windows programs:
uspasp driver:
here is the driver and manual for the chip programmer…read page 7 for install
scroll down for the driver download and manual pdf
If you plan to do this for the first time, I would recommend adding a board like this to your purchase list. It allowed me to program a dummy part without tearing apart my light and risking damage the first time. The one I bought was local and cost less than $4. In the total cost of things it was worth it for sure.
Also DEFINITELY use a wooden tool to try to remove the board. I forgot this on my second attempt, broke a chip resistor using a metal object, and still have not recovered, even after replacing the broken part. I think my clip is just not connecting, but I have put this project down for a bit.
Hey, it’s a good tip though, what you said… for sure I’ve busted up some driver components trying to bust glue before just like you said. I’ve learned to eyeball down in the hole and maybe feel around a bit with the tip of a small jewelers screwdriver in an effort to get on the pcb before hitting it.
I remember one that was a true PITA, couldn’t get it to budge. Finally got it all apart and it was the strangest set-up, they had a small driver board up top of the contact driver board and I had knocked the screwdriver all the way through that first board! Totally annihilated it, what a mess! lol (a solarforce light, if I recall correctly. Had a top board soldered into a brass holder and the bottom board also soldered in then the assembly is press fit, sure a trick to get out)
Changes compared to the previous version of RampingIOS V3:
Added a moon timing hint. When doing a hold from off, this blinks when passing the threshold between “click” and “hold”, to indicate when to let go for moon.
Better timing consistency on hold-from-off. (before, the stepped ramp took an extra 0.4s to start ramping up)
Fixed a bug where changing ramp style could go to the wrong brightness level. (go to a med mode, turn off, hold for moon, click 3X to change ramp styles, and it’d go to the med mode instead of staying at moon)
Added a D4-219C build target. (FET ramp power reduced to 80%)
Wasnt able to reset password. New problem. The light had problem with switching off after got warm, and had been turning on often, but last time it just couldnt turn off so i had to twist head off. I contacted hank but he only said to take bezel off and look there for some screws, but i dont even know what bits to buy, are they philips or waht. This being asked, hank evaporated disappear. Very pity that i actually sent him the whole amount too fast.
Said:
Looks like there is short somewhere, would you please unscrew the bezel, take
the optic out, then try to take those two screws out, and see if it will work fine again.
But when the screws are not there, please use the low mode only, not the turbo mode.
If the light is stuck at a bright mode and won’t turn off, it generally indicates one of two problems:
There is an unintended connection somewhere, allowing power to bypass the driver entirely. If this is true, then the light should act like a 1-mode twisty — tightening the tailcap would turn the light on at a very high level, without even pressing the button.
A button wire is broken or shorted or disconnected. If tightening the tailcap causes the light to blink then turn off, but it doesn’t respond to button presses, this is probably the issue.
There was a week long holiday in China. Everyone is just getting back to work.
Most flashlights are easy to take apart. I’m sure someone here can walk you through opening up a D4 if you ask. It is probably somewhere in this thread…
