Yes, that should work fine. It is the same part that Astrolux uses.
After a month, my most recent BLF A6 started rattling when shaken because the lens is loose and taps the sides of its housing. It’s tightened down as much as it will go.
Any suggestions on a fix would be appreciated.
Do you have a spare O-ring to put between the lens and the bezel?
That worked. Thank you!
Although my other A6 does not rattle, I’m going to do the same thing to it to prevent debris from getting under the lens.
You’re welcome
BLF A6 / Astrolux S1 quality control is very flaky, hence the variation. I have an A6 whose bezel only screws down properly if the O-ring is between the lens and the reflector (which compromises the water resistance).
I need to experiment with some spare parts to see if I can fix that. Alternatively, I might transplant the LED and driver to a Convoy S2+ host I have lying about.
New member here. This light was my first purchase. My is rattling after only 2 days… So if im. Reading this correctly, oring above the lens and another around the reflector in the groove? This won’t put too much pressure on the pcb? Or the reflector? Just wondering.
Yes, there should already be an o-ring between the reflector and the lens. Now add one of your spare o-rings above the lens to hold it firmly in place. I don’t know about the pressure issue you mentioned. But it seems to me that if the lens is shifting, there should be enough give for the additional o-ring. I’ve done this to my EDC A6 with no issues so far.
Ok. Great. That’s what I’ll do. I love this little light. It’s a perfect put in your pocket everyday and tell friends, look how bright this light is for its size. Will this affect any dust ingress?
Agreed. Great pocket power light. This should keep all dust out that may otherwise enter due to the loose lens. If you touch the lens in the process, you’ll want to wipe it clean. Be sure you use a LINT-FREE cloth, or you’ll end up placing micro lint particles on the inside of the lens.
So I got a pretty difficult request.
Does anyone on here have the CAD drawing for the BLF A6, and the Astrolux S41? Even just the head and bezel.
Sorry in advance if this is way out of line to ask for
Hi all,
I just received a BLF A6 driver from banggood, and I just have a couple of user questions, as I think my driver is not working properly. It seems to be in the 4 mode at the moment, so Low,Medium,High, Turbo.( Comes on in low I think, not moonlight) I can’t seem to access the config modes with 15 clicks, the light just keeps changing modes, I have tried both full clicks( ON/Off), and half clicks, but I never get to those 2 blinks that signifies config mode, am I doing something wrong?
If I do the medium press from the first Low, I get Turbo, and subsequently Strobe,Battery Level,Bike Flasher. Battery Level doesn’t blink, just constant low, so I guess it doesn’t work properly?
Any help/advice will be appreciated, thanks!
Flitsmal,
turn on the flashlight first (full-press)
then half-press 15 or more times, until the flashlight will do a sequence of 2 blinks. (observe first, don’t do anything yet).
Be observant when it does that “blink — blink”, pause a short while, then another “blink — blink”.
You need to turn off (full press) during the first “blink — blink” (after the 1st blink but before the 2nd blink) = this will switch from 7-modes to 4-modes or vice versa. (ie. blink — [turn off])
Now, to toggle mode memory, do the configuration again, wait for the “blink — blink”, then “blink — blink”)
(ie. blink — blink, pause, blink — [turn off])
Hi d_t_a,
Thanks for the quick reply, I have tried thanks, but it will not go to those blinks, it just continues to go through,low,medium,high,turbo. And like I said, there seems to be no moonlight
Don’t bother counting 15 clicks out, power it on and just half press it until it stops getting brighter.
From memory you have to start the quick presses from low mode and moonlight was only on the seven modes. Keep pressing quickly until the light stops responding to your presses.
On further reflection,I might have damaged the driver with over voltage, I was testing with a power supply, and a battery, and instead of using a multimeter on Amps, I accidentally added 4V from the power supply to the back of the battery… the bond wires on the led blew, but I am lucky enough to have those fixed at work So, I fixed the led, but maybe the driver was damaged in some way with the 8 V I combined whenI added the power supply to the battery.
It’s just the moonlight I miss really, as I still have at least 4 modes, with the quick access to Turbo….
Thanks for the inputs
If you’ve still got modes its still working.
Does this light have a lighted tail cap?
The modes were doing really weird things on one my lights after I did a spring bypass. I reflashed the driver and that fixed the issues. If you have the know-how perhaps you should consider doing that.
No lighted tail cap that I am aware of. I put the driver in my old BLF Eagle Eye X6.
No, I don’t re flash drivers, that’s just creepy/weird
But it definitely has no moonlight now, I can’t get to the 7 modes or the configure modes, and the battery checker doesn’t blink, it just stays low( But I know it’s the battery checker mode, because it has the strobe before, and the bike flasher after…)
Cheers
Sounds like maybe the 7135 chip died, which would also cause the battery check mode and config mode to not look like they work. The amc7135 chips don’t respond well to excess voltage, even if other components survive.
