The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
I love blf gt so much… :slight_smile: I might give one NW to my dad, since I already got one NW from TA.
Is there any estimation of battery life for the GT70 NW with 8 cells (30Q) installed?
Sorry if this has been covered before but Google did not come back with any useful hits.
I’m debating whether to buy a faster charger (I currently have the Nitecore D4 and I’m looking at a Nitecore I8) for my batteries and if the GT70 chews them up fast enough then that might give me the excuse to go ahead with a new charger. :slight_smile:
All 88 is good, but they sell for $55 plus s/h
I don’t think there’s been any official run time tests with the GT70. With 150 brightness levels to give smooth ramping you probably need to switch to mode sets, pick a level and see how long it holds it. Maybe someone with 8 30Q can test this.
I thought about that too, run time for set level should be helpful in estimating run time for other levels.
Just received my unit and charging all 8 batteries. w00t!
Dang, waiting for the batteries to charge is like watching water boil. :P
Another question on batteries.
I know that I need to use matching cells within each 4X battery carrier and I ordered 8 30Q batteries with my GT 70 so I’m good to go.
I currently have a Nitecore D4 charger that only charge 4 cells at a time which means doubling the time needed to charge all 9 of the GT70’s batteries.
My question is if I don’t have time to charge both sets of 4 batteries and only charge one of the two battery sets, will it be safe to use both sets together with different charge state since they are connected in parallel?
NOOOOOO…
Never put cells in parallel in different charge states. That is really bad for the cells, as there is going to be a huge amount of current flowing only limited by the voltage difference and internal resistance of the cell, well above the maximum charging rate of 4A for the 30Qs.
I sure hope this works with the flattop "30Qs" I just got in because my light should be here tomorrow or the next day. I say "30Qs" because these cells don't look like the other 30Qs I have. These still have a pink label but instead of the other markings I'm used to these just have a white label that say "IMR 18650 3000mAh 3.7V" I hope 18650batterystore.com is legit.
You’ll need to solder blob then most likely.
Ah right, the charged cells will be charging/leveling off the other batteries of lower charged state in unregulated rate and that can’t be good.
Got it, thanks! :slight_smile:
I believe you can run just one carrier with batteries. Check the manual.
Of course it’s better to run 2 carries w/ equally charged batteries to split the current but it is possible with the right batteries.
Blf gt70 doesnt even get warm running around 2500 lumen…
Yep, it can be run with just 1 carrier loaded… no problem at all. Runtime will approximately be cut in half.
I got mine a couple of weeks ago. It’s a great charger.
Finally, batteries all charged. What a light. Besides the intense hot spot, it has a nice spill, much more than the original. I also did a side by side comparison between the GT70 and MF04S. Both are NW. Lights are very similar in the size of spot and flood they throw, but the GT7 with 1500+ more lumen definitely dominates. :-)
Mine came in today in perfect condition - It’s nice but I’ll have to change the emitter for something warmer - too much glare for me.
still glad I got it. :slight_smile:
Sheesh. Just finished charging all the batteries. And that’s with all 8 charging at once lol. Ok so I turbo’d it to a structure about 250 yards away. It doesn’t light it up like I had imagined. The beam is nice and wide but I want more throw and am willing to sacrifice the spill. Do I slice off the dome?
That is about the only thing left. Slicing it off loses maybe 15% of the lumens, but it makes the hot spot a bit smaller and more intense.
