[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
nice to see will run of 18650 as well!
Can someone break down the typical uses and characteristics of these 5 different LED choices?
I have a NITECORE HC33 with the CREE XHP35 HD in whatever white tint it comes in and a THRUNITE TH30 with the CREE XHP70.2 LED in Cool White. The THRUNITE seems yellowish to me and pretty floody. The NITECORE is more of what I would call white and throws way more with a floody spill. I was wearing both last night in the grape vineyard, both on MAX at the same time and it was great! I could see 100 yards forward and about 30 yards to each side in vivid detail. Those purple grapes just popped. Had a C8 XM-L2 Cool with me as well, and when I turned that on I could see 300 yards forward, about 200 yards extremely well. Found four cats wondering what the heck I was doing. Lots of particulate floating in the air. Startled an owl…
I am interested in getting 2 variations of this light. I don’t have a favorite tint or kelvin number. I like icy cold blue. I like slightly warm. I like anything in between. I would enjoy having a very flat neutral non artifact or hot spot flood for photographing products. Not sure what type of emitter/optic combo would best fulfill that need… The other could be anything. Eager to hear about the flavor of these 5 choices and why any of you are passionate about a certain variety.
2 lights up!
Interested
For photography I’d go with high cri. Tint and Temp can easily be adjusted. For pure even flood that covers the whole frame then a mule (no optics or reflector) is the way to go. I’m not sure how difficult or easy it is to remove the bezel and optics from this light though, or if the mcpcb is screwed down or just pressed by the optics (maybe TK can answer this). I have used a d4 for photography and I find that even the very floody Carclo 10623 optics produces an uneven light so I remove the optics for this purpose.
The prototype I have seems to use press-fit retaining rings for the lens and the button, so I haven’t been able to take the head apart at all.
This makes me a little bit sad. Press fitted bezels are a PITA to work with. I’d still buy this light for its form and UI (thanks to TK). But hopefully the final version is more mod friendly.
That’s the reason why I’m really looking forward to the FW3A with LH351D, based on Toykepper’s comment it should be nice for close range work or photography :
Interested
Thanks
I kinda agree with this. For normal use I usually don’t like the flood beams of mule lights and zoomies especially the rough edges. Judging by the sound of it, I probably wouldn’t like LH351D under quad or triple optics either. But you’re right, they might be very useful for close range photography.
Interested
Interested, Thanks.
Interested
I am interested
I’m in thanks.
Interested.
Interested
Is the PL47 really going to have that odd two tone body? It’s up on the Fireflies site with no colour option and the description is unclear. I always assumed it was just a prototype.
Does it come with a Head-strap ?
Definitive interested in two if it does.
I like the champagne/sand/FDE/burnt bronze look with two tone. That’s what attracted me to this at first. If it comes in all black I will be sad.
Yes, we sourced back a head-strap to make it work as a steady headlamp.
