To all of you much more experienced: I do not want a new flashlight now, but will probably buy one in the not so distant future. Will the price go down in the next 6 months?
Also, is there any hope for a well driven XML 14500? Or the 14550 is simply not powerful enought?
with 14500 you will not have the full power of the XML. With 14500 you will have to use IMR cells... and the runtime will be poor.
However, a 14500 flahslight, with a driver limiting current at 2A with 14500 and XML is possible, More than 2A on an standard 14500 cell .... possible but not recommended
I will put a XML into my A20 [ 16340 ] , for a pocket rocket .. @ 2A ?? Hopefully 1.5A as it does 1.5 with the Q5 ATM , so if I can get 2A with my better 16340's .. It will rock for a EDC ..
I think the price will come down some in a few months as these become more widely available. Because the LED die area is larger, I don't know if they will ever come down as much as a XP-G.
It's a higher bin at 350mA, so at any current, the XML will put out more light. But I imagine the hotspot won't be as bright as the XP-G, which wasn't as bright as the XR-E or XP-E. But if the current isn't regulated, it would be like runnning a XP-G from a 10440 and suck the life out of a 14500 in no time.
Cutters prices have gone up !!! Used to be $7 for a XP-G now almost $10 .. With the Ozzi banana going up in value the price should have come down , but not so ..
Ah well, we'll see what arrives when the dropin finally gets here - which is not likely to be any time soon - last package to arrive from HK had spent 7 weeks in the HK Post Office.
KD said my XM-L drop-in shipped December 2. HKP showed nothing until today when they said it was posted December 3 by the shipper. So it still hasn't left HK yet. Just got an order from ITC in 10 days, so I hope to get this towads the end of next week . . .
Meanwhile Thrunite and EagleTac have announced XM-L lights, but I don't know if they are shipping yet.
Thing is, even once it gets out of HK, the UK has had a lot of unexpected snow and it's caused chaos on the roads and railways. And, as a result with the mail.
Hello everyone. I've been a flashlight fan for many years, but didn't know there were communities like this until recently, so I've had a lot of fun browsing your message forum. Thanks for sharing everything here for others to learn. I've got a (ShiningBeam) MG P-Rocket 1x18650 SST-50 running at about 2 amps that I love as well as a very nice/portable Fenix LD20 CREE XP-G R4 2xAA, but I'd like to also get something a little brighter. I'm considering one of these T6 CREE XM-L lights from KD mentioned in this thread. My main goals are a very bright light I can bring into a large attic/shed when rummaging around or to bring into the woods around the house, so I need some flood and throw is not as important. I don't care as much about runtime, since the light will stay at home, but a usable low mode < 75 lumens and tailstanding would be a nice bonus. I'm trying to spend less than $100, which actually seems to rule out all of the SST-90 lights I've seen. I'm not an expert in much of this, so I have a few questions.
Are these T6 CREE XM-L lights likely to be brighter than my mid/high end SST-50 1x18650 light @2a?
There are 2x18650 and 1x18650 versions of the T6 light. Does adding the second 18650 mainly increase the brightness or the runtime? Or does it depend on the electronics?
Would these XM-L lights be as bright as a SST-90 with 2x18650 2900mah AW batteries? Or should I look for other LEDs like a P7 for more lumens with that type of power input?
A lot of good questions and the main answer is we'll just have to wait and see. The XM-L should put P7's and MC-E's out of business. SST's can still put off more light when driven to higher currents than the XM-L will permit (over 3A). At 2A they would probably be about equal, but the smaller LED of the XM-L should throw a little further. We'll have to see how hard the KD drop-ins drive the LED. If they drive it to 2.8A or greater then 1 18650 isn't going to last very long at all, and I suspect you won't see very good regulation (it will start off bright and then dim steadily). If they don't drive the LED as hard, then the brightness isn't going to be all that great. I do think they'll be floody like what you want.
Once good drivers are out there, I expect the XM-L to completely replace the SST-50. I doubt that Luminus will still be making the SST-50 by March. Already existing MC-E driver will make theXM-L beat the SST-50 which needs 5A to give of its best, the XM-L promises the same output at 3A.
But until they are in general circulation this may, or may not, be the case.
Thanks brted and Don for your help. I'm not sure if I'll go ahead and buy the KD XML T6 2x18650 now or wait a few weeks until someone has more info. I wouldn't mind installing a more suitable driver if it is easy and the factory one isn't that good.
From the info here, I'm guessing that having a second 18650 battery (instead of just 1) mainly increases the runtime (not brightness), unless the driver in the 2x18650 body draws more amps than a single batttery can supply? Is that right?
phlowcus, here are the 2x18650 XM-L lights I've come across recently (only the first will be a "budget" light, I assume):
I received my shipping notification last night (2 weeks after ordering). Lets hope the driver and reflector are up to the task. Early flashlight mods indicate that the XML plays nicely with many different reflectors, including XRE, P7/MCE/Rebel.
