The original 219B has a higher Vf but the 219B V1, which is the one sold atm by Clemence and maybe others, has a Vf just as low as the 219C, but indeed without its current handling.
The D4 is unusually sturdy. Every part of it is thick. I don’t think it really needs to be so thick, except up at the head for thermal purposes.
The FW3A is thinner and has its material split between two layers. It opts for a more minimalist design in general, so it won’t hold up as well to being run over by a car. OTOH it also weighs less and is more ergonomic so it’s easier to carry.
They have reflectors and tall springs, and a non E-switch tailcap. That makes for a wide difference.
In relation to the contacts, what decisions have been made? Are we going just with double springs, or are we going to push limits with dual BeCu springs?
Emisar’s lights are slightly thicker than a S2+ or A6. However, yes, I think the S2+ and A6 could also stand to be shorter and thinner. Potentially about 2-3 mm thinner and 15-20 mm shorter. I have other 18650 clicky-switch lights that size, and I prefer them because they aren’t as big.
This is pretty disappointing, but I did just successfully reflow a FET with great success using my new hot air reflow station. Maybe I will try leds next.
Quite. Which is also driving my strong interest in this, DEL’s driver with x1 and x7 (I think) AMC chips.
That is huge, having regulation (and efficiency) at all usable levels. Goodbye FET+1.
Plus Anduril of course.
I couldn’t care less about the FET, that’s just for headline figures for a few seconds on a torch of these dimensions, and over-powered-ness (if that’s a word).
Putting an E-switch in the tail, with all the knock-on complications, is bold. Very bold IMHO, but if it works, great. The tail is the proper place for the switch on a torch of this size.
Let’s hope Lumintop don’t glue the thing together, that the fancy suit fits well and somehow dissipates some of the heat, then we can mod-on happily.
Fun times ahead. I’ve only reserved two, maybe I should up the order ?
I have many 219c 90CRI 4000k lights (reflector and optics) and they are very yellow when compared to the 219B 9080 4000k, E21A 4000k, and Cree 5D tint. The LH351D 90CRI 4000k looks similar to the 219c and also looks very yellow. I would take a Cree XP-G2 70CRI 4000k 5A or 5D tint and color rendering over a 4000k 90CRI 219c or LH351D because the yellowish tint ruins the high CRI.
Is the picture above an accurate representation of the size of the FW3A and the Emisar? I was under the impression that there was a bigger difference, and the FW3A was smaller.
That was the first prototype, I guess, so maybe it could have changed meanwhile!
Only the ones having the most recent one can say something!
Still, being (slighty) smaller than the D4 is already a thing to be noted!!
Interesting. For me personally it would also be interesting if a 14500 light could be slimmed down in a similar fashion - my notion of an ideal light to carry every day
