Quite. Which is also driving my strong interest in this, DEL’s driver with x1 and x7 (I think) AMC chips.
That is huge, having regulation (and efficiency) at all usable levels. Goodbye FET+1.
Plus Anduril of course.
I couldn’t care less about the FET, that’s just for headline figures for a few seconds on a torch of these dimensions, and over-powered-ness (if that’s a word).
Putting an E-switch in the tail, with all the knock-on complications, is bold. Very bold IMHO, but if it works, great. The tail is the proper place for the switch on a torch of this size.
Let’s hope Lumintop don’t glue the thing together, that the fancy suit fits well and somehow dissipates some of the heat, then we can mod-on happily.
Fun times ahead. I’ve only reserved two, maybe I should up the order ?
I have many 219c 90CRI 4000k lights (reflector and optics) and they are very yellow when compared to the 219B 9080 4000k, E21A 4000k, and Cree 5D tint. The LH351D 90CRI 4000k looks similar to the 219c and also looks very yellow. I would take a Cree XP-G2 70CRI 4000k 5A or 5D tint and color rendering over a 4000k 90CRI 219c or LH351D because the yellowish tint ruins the high CRI.
Is the picture above an accurate representation of the size of the FW3A and the Emisar? I was under the impression that there was a bigger difference, and the FW3A was smaller.
That was the first prototype, I guess, so maybe it could have changed meanwhile!
Only the ones having the most recent one can say something!
Still, being (slighty) smaller than the D4 is already a thing to be noted!!
Interesting. For me personally it would also be interesting if a 14500 light could be slimmed down in a similar fashion - my notion of an ideal light to carry every day
The L10C is also a good alternative to the L10 if you don’t mind the longer body.
No memory and always start on the lowest mode (Moonlight or Low depending if you bough 3 or 4 modes version), available with Nichias
My main interest in this light is the tailswitch and overall size…though hopefully those prototypes aren’t accurate as I was secretly hoping this to be the size of the DQG Brass beauty, with the fancy and efficient ramping UI and triple emitters, since that particular light no longer seems to exist…
If you like that, you might also appreciate Mike C’s approach. He has a 4-channel driver that uses banks of AMC7135’s additively to increase current up to the max level of the driver. Only a single AMC7135 chip is PWM’d so most mode levels are completely PWM free. The PWM channel is for modes below 350mA current.
Been catching up on this light. Can’t wait to get it in my hands, great work.
I see that two different emitters are listed in the results:
Poll (2018-06-08): Voting is open for emitter details: (results: the top choices were XP-L HI 3D and LH351D 4000K)
If you’re going to offer both emitters, I’d like to change my order to 4 lights total (already have two, 1148 and 1149) and get two of each emitter type. If you’re only offering one……Oh heck, I’ll still take 4 total. These will make great presents.
Thank you very much for all your efforts, build team.
