That’s awesome.! Great work it’s really bright with the Nichia, at least for the five minutes I got to hold mine until my wife “secured” it for herself. Ah well waiting for the copper version for me
I think I saw someone said the S43 works with the prior S41/S42 18650 tubes. Those have knurling but are a good bit shorter I believe, I need to measure. Maybe it’s the button which makes the tube seem longer. I have an extra old one I’ll have to try it. Now how to get it back from her for a few minutes …hmm
Can someone try that if the light is locked and hit the tailcap upwards with hand (Of course the spike removed ) ? And The question is if it jumps out of lock because the little battery disconnecting or not?
That is not very good. You need to lock with tailcap in a bag because if you drop down your bag harder it can unlock itself. Maybe I will put in some spring in mine when it arrives with wire bypass to not make output worse.
I had ordered a pair of the S43s from Banggood.com and they just arrived today. I’m planning on giving one as a gift. You are right nokoff, the interface is awesome. That is my thought any time that I get a flashlight with NarsilM as the UI. The light out of these is quite nice and bright. It does seem to get hot pretty quickly when the light is set on high or turbo; it is a small head with 4 LEDs, so that is to be expected.
With the pictures in the forum and seeing how much better the prototype looked than the Astrolux production version, I was pleasantly surprised that it is a decent looking like in person. It does seem kind of naked without any knurling on the body, but the little bit of knurling on the end cap helps it a bit. But overall I don’t think that the pictures do it justice. That being said, I did contact Neal, following the link for the Mateminco S03 over at M4DM4X.com at the end of last week and asked about ordering a couple of the long tube bodies for the S03. He said that he just hadn’t gotten around to posting them on his page yet, but that they were $2/ea. + shipping. I went ahead and ordered two of those for a total of $9. I’m anxious for those to get here and see which I like better. So if you do order the Astrolux S43 and don’t like the body, you can change it out if you are going to use at 18650 battery. I’ll let you know what I think when they get here.
Totally ageee that the stock Astrolux photo front 3/4 angle was the worst possible angle they could’ve shot their new torch. Looks really good in person.
Thanks for the link! That looks amazing with the S41 Special LEGO. I wonder if the new special metals, rainbow and SS, will get the longer S43 18650 tube or they’re just going with their current stock of S42S. If they go with existing stock, that’ll make some people happy since it has a flat bezel. I personally don’t mind it lightly crenulated because sometimes I stand my torches up on the bezel and I can tell if it’s on; as long as it doesn’t scallop the beam it’s fine with me. It would be nice to see the longer S43 18650 tube in those metals.
Texas ACE hinted at something special, I hope that means full ti or copper!
Is the Nichia version throttled by a lower duty cycle (like the D4S), or is it just down to the differences in efficiency and Vf?
I’m going to preorder A S43s and I plan to do an emitter swap with SST-20s. If the firmware is the same between the two versions, I’ll get the Nichia, since I’d rather have extra 219c than XP-G3. If the firmware is different, I’ll get the XP-G3 version so I can avoid having to get the driver out to reflash.
The Nichia version uses the same driver and firmware as the XP-G3 version. There is no need to cap the max output in this light since it will be battery limited anyways with 4x LED’s powered by a single cell.
They don’t have to limit output on the S43 since the contacts aren’t designed to push power to the absolute max with the lowest resistance and traces like the Emisar D4S.
Therefore, unless you mod the heck of the S43, you will not need to limit output on the S43.
Can anyone comment of the weight difference between the aluminum version and the copper version? Banggood says they both weigh 60g. I doubt a slightly longer battery tube on the aluminum version can make it weigh the same as the copper head 18350 version.
Also, has anyone measured the lumens on the Nichia version S43? With its reduced battery contact resistance, it must gave higher output than the 1600 lumen used in the S42.
I believe the D4 also uses duty-cycle throttling on the Nichia versions, but as you note, it is a different light, with different contacts, etc.
I do have some Emisar springs, I was thinking of using one on the driver side, if it fits (and if I buy one of these). I have other options for the tailspring .
