They don’t have to limit output on the S43 since the contacts aren’t designed to push power to the absolute max with the lowest resistance and traces like the Emisar D4S.
Therefore, unless you mod the heck of the S43, you will not need to limit output on the S43.
Can anyone comment of the weight difference between the aluminum version and the copper version? Banggood says they both weigh 60g. I doubt a slightly longer battery tube on the aluminum version can make it weigh the same as the copper head 18350 version.
Also, has anyone measured the lumens on the Nichia version S43? With its reduced battery contact resistance, it must gave higher output than the 1600 lumen used in the S42.
I believe the D4 also uses duty-cycle throttling on the Nichia versions, but as you note, it is a different light, with different contacts, etc.
I do have some Emisar springs, I was thinking of using one on the driver side, if it fits (and if I buy one of these). I have other options for the tailspring .
You should try holding one, that is if you haven’t already. I like the knurling on the prior version s as well, especially the stainless steel editions, however these torches are so small that you can’t help but hold the tailcap and body tube at the same time. It’s not slippery when dry, maybe only slippery when wet. ;). Remember the newer tube is longer than the prior tubes. Even if you don’t use protection, I find it easier to load and tighten a battery even if it’s just a comfort thing. I like both options.
BG lowered the shipping to almost nothing as well since it’s a preorder…just saying it’s probably the best time to pick these up that there ever will be without padding the order, at least for us in the states.
Jason I have several S41 and Manker E14 models with and without the copper heads and steel and Aluminium bodies. . The 18650 battery tubes in Aluminium pretty much level them out in weight distribution front to back. With the 18350 it’s a noticeably heavier copper head. With the 18650 tube the weight is still up front however you won’t feel it unless you balance it for grams. I prefer the copper heads myself.
Okay I went for the copper Nichia version. It seems the light will be ready Oct 31, but the 18650 tube not until Nov 10. I wonder if they will ship them seperate or hold until they can ship it all together?
I’m also assuming this light uses the common 20mm triple quad mcpcb that lots of places carries. If I don’t like the nichia, I can always try something else. Maybe even a different optic.
It using it’s own quad optic. Sadly it is smaller than carlco 10602 quad and bigger than a triple 10507 so nothing will fit perfect. The astrolux optic has 22mm diameter. The easiest way is to fit a triple because MSPCB is 20mm and the glass will hold it down or you need to reflow different leds to the factory MCPCB.
If you haven’t yet, you need to read up on the Narsil interface. It’s fairly intuitive, but there can still be questions like yours that are answered in the documentation. Unfortunately, I don’t have a direct link. But if you search around BLF, I’m sure you can find it yourself. (sorry)
