Considering the XTAR 2600 uses Sanyo cells and the wrap is quite good I'm still collecting those. The Solarforce batteries are good but the wrap is crap. I'm wondering about the Hi-Max though
I just did some tests on some XTAR 2600's about 9 months old (probably only 10-20 cycles). I wanted to do a test so I could compare them against the new ones I have on the way. Only got about 2199 and 2294 mAh at 1 amp using Turnigy Accucell hobby charger down to 3V. Disappointing. I haven't used them that hard and would have thought they would hold up better than that. One of these (not sure which) measured 2472 mAh when I first got it.
CheapThrills said in the group buy thread (last post right now) that the new ones seem to perform as well as the old ones. Also be aware that they are fatter and don't fit in all lights.
The TFs arent bad, I got 4 TF3000 from MF and 2 TF2400 from DX (those are fake, tho I dont think they are bad) and they all work very well. But its just as it is when you start with something new.. my first flashlights cost less than 10$, now I spend multiple times of that. So naturally, I'm willing to spend more on batterys, too. There is always something better.. always!
If you have the purple XTAR 2600, it may not fit your L2P. I have a couple of those purple ones and none would fit the new L2P I received about a week ago.
That's a fact. NEW XTAR 2600's will not fit in the NEW Solarforce L2P. They will fit in the older L2P's, however. I have both older and newer XTAR 2600's along with older and newer L2P's so I've tested this.
i just recieved some purple xtars from pandawill (they shipped from within the us and for two new xtars it was 13.50 with free shipping. got them in 6 days. 2100 did a discharge test on one of his purple xtars with pics in another thread (search "purple xtar" and the post will come up. he got around 2200 mah i think. cant remember exactly, and im on my phone right now or i would post the link to the thread.
Edit>
Here's 2100s dishcharge test of the purple xtar 2600:
https://budgetlightforum.com/t/-/4453?page=1
Post #77
He got 2288mAh
I mostly have TrustFire 2400 Flames from DinoDirect. Somehow all of mine are real, but I mainly use my pair of Hi-Max 2600s because they're better. You can save a little money on the Hi-Max by making an offer to pingyi.co.ltd on eBay.
