Just recently modified my keyring setup again to now include.
47's Atom Triple XP-L HI v2 1A 1700lm H17F with reverse clicky tail switch.
DQG Hobi Ti+ Seoul Viosys 365nm UV flashlight with 10250 cell & Petrol lighter.
DQG Ti 532nm green laser with tail switch.
CRX Ti mini ferrocerium rod.
True Utility Telescpoic pen.
Slim steel folding Nail clippers.
Tec Accessories Ti Tritium fob.
Lights are on magnetic holders.
32mm Titanium split ring.
Nowadays Astrolux AO1 on keys in pocket,
Have 10440 cells but use Std AAA in it.
I also carry a Jetbeam Jet-1 MK Pro with 10440 cell When we go out.
That gives the extra output if needed.
Each car has a No Name. (Very good 18650 cell 4/5 driver)
Plus the usual, in home, Garage. by pool, on boat.
C8.C8+ etc, up to L6 and SkyRay 9 x LED coke can. for further reach.
I’ve just recently bought a BLF348. but don’t know where to put it yet.
Sits on Table beside TV chair with several others at moment.
Using Olight I1R right now with a vic classic, but I rotate it once in a while with I3eos, fenix ld01, nitecore Tini, 47’s mini cr2, and sometimes swap the vic classic for vic signature light for the pen
You are such a tease Pictures please or it didn’t happen. And would just light up your chin, unless you have a particularly impressive embonpoint or spectacular bra. Maybe Lady GaGa, leather bondage style outfit. That could work.
Leather. Nice.
Meanwhile I have the Nitecore Tube, and the TIP. the Tube is quite weak but does the job and is by far the best little re-chargeable keychain light, on a budget. The TIP is very strong, probably all that anyone might need, and versatile, the UI and power management is OK. Efficiency seems very good to me and the internal cell is good. Summary: these are both good.
Don’t bother with the “Tropical” finish that I chose, it’s not hard PVD, just cheap plating that is already crumbling off after half year. A disappointment. Just buy the plain SS, or AL versions (or if you must I think they offer a Cu version. Why ?, unless you are a patina fetishist)
Smdh how about a little respect for your fellow BLF member… There’s plenty of places to see boobs on the internet, this isn’t one and I’m 10000% sure she doesn’t come here to be asked for them.
I wish I was a woman so I could carry bigger flashlights between my boobies…
Well, winter is here and I can wear sweatshirts with big pockets… two good reason to finally EDC my D4 !
Carry a DQG mini aaa xpg2 nw in the coin pocket of my jeans, a photon freedom in my other pocket, and a nitecore tube on the keychain. When going out at night something bigger as well.
failed to answer all the questions previously :person_facepalming:
Is it a AA or AAA or lion? 18350 Li-ion
Why’d you choose that one? Its the best UI, high enough hi, low enough low, small enough for me
How long have you been carrying it? 5 months
How often do you use it? multiple times a day, especially this time of year.
How’s it working for you? :+1:
How’s the wear-n-tear on the finish? Like new except for a small surface deform on a corner where it was dropped, ano is fine, just a small flat spot
Do you carry more than one? no
My key chain light is the Harbor Freight 70 lumen single emitter ( NOT the 9 led ) version. Decent CW beam that serves purpose with close range lighting. Triple AAA in carrier powers this light
BTW, this is free with any purpose from Harbor Freight
I have 2 both are Aleto k209b twisties. They run of off 16350 batteries at 1 amp.
One head has the xml dedomed while the other is standard.
One tube has a pocket clip installed and the other a short chain with key ring.
Have had them for about 2 years. The finish is ok though they both have a couple of scratches. The pocket clip wears down the finish on the heads a bit.
I chose them because they are so cheap that they are almost disposable so I won’t cry if I lose them while working. The light output is impressive for the size at over 300 lumen on high and the low beam is very usable.
The tint and smaller hotspot on the dedomed head is definitely my favourite.
What I don’t like is the strobe mode and I’ll eventually sort that with a 7135x3 or 7135x4 driver and possibly upgrading them to newer emitters. Runtime is also not the greatest but I rarely use them for more than 10 minutes in a day.
