Before it died, were you able to measure the capacity of the cell? It’s possible it could be a fake.
>>were you able to measure the capacity of the cell?<<
No I haven't tested the capacity ,,,,I don't know how to do that ?
Not long ago I bought the charger
Thx
>>It’s possible it could be a fake.<<
I want to find out
Perhaps this thread of mine about the Sanyo brand compared to the other major manufacturers has some commonality about the Sanyo brand:
Thanks tatasal
I read your thread
What is your recommendation brand (based on your experience ) ? and where can I buy them (preferable ebay) ?
I bought my GAs from Banggood, though now that you are yourself apprehensive about its longevity as I am, I’d rather get Samsung, Sony or LG.
So far the LG followed by the Samsung are the most durable among my cells with regards to battery life and capacity retention, even after repeated deeply discharged conditions, and even from long-term less than a volt state-of-charge.
>>So far the LG <<
I will try LG
From where did you get them ? can you please send me the link
Hello Zillah!
The cell and charger you chose are good quality, however a words of caution about eBay, it is flooded with poor quality cells and some fakes. Some are ridiculously overrated, incorrectly priced, and in general very misleading.
I had to learn the expensive way, Being a newbie without much experience. Everything changed when I found a specialized seller, LithiumIon Wholesale, www.liionwholesale.com. They have an excellent selection of highest quality cells with great pricing and great support. Only caveat is shipping expense for your location.
The 3500GA is of the highest capacity 18650 cells available. On the Liionwholesale site there are very detailed instructions on proper charge technique and important DOs and DONTs, as well as extensive useful customer reviews. Read and follow those recommendations, and I think you will have a completely different experience. Even if you buy elsewhere, the knowledge there is unbiased and invaluable, which earned my business. Hope this helps.
The LG MJ1 3500 mAh cells (Green) I’ve had superb experience with and should be an ideal solution for
Your Boruit headlamp. Make sure you select the button top variety.
Best of Luck my friend!
Thanks Ocelot
Yes that is true.
Noted with thanks
Hi.
I’ve got the Panasonic 18650A’s Protected and UN protected.
On multiple Torches. for a few yrs now. So far. OK Still holding capacity and giving enough output for What I use up to XPL-Hi.
Recently I’ve bought some Samsung 30Q’s. which have a 15ma output over the 5 or 6 of the A’s.
they get a VERY good rep from most of the experienced on here I find.
And cover the output for my Convoy L2/L6/C8+ and a coupla other heavy output ones.
I think you’ll find that the max capacity battery’s are not the max, output ones,
that seems the domain of the 2600ish capacity ones from reading.
Here in AUst we can’t get cheap battery’s Aussie mail won’t allow battery imports. we have to pay full price ($27-$45each)or make do with the backyard dealers that don’t supply genuine items.
Seriously doubt there is anything wrong with those cells. Been using many of those GA’s for a long time. I’d start by getting a better charger. I’ve had mixed experiences with that UM20 flat top vs button tops. Taking too long to charge. Finding a high enough Amp usb wall wart to power it, and not being able to charge an over discharged cell.
The Nitecore D2 or D4 are nice. The Opus BT-C3100 will allow you to discharge, charge, and test your batteries.
A few short remarks about the previous entries.
- How about the on/off switch on the Boruit light. They are notorious. And what about parasytic drain?
- GA’s are good cells. I agree they’re not the problem. But unprotected can’t cope with the previous issue.
- I own the OPUS, not a bad word. But generally XTAR chargers have a revive modus that enables them to revive Li-Ion batteries that are not recognised as such by the OPUS charger. (batteries at 2.0V are invisible to the OPUS)
Oh I forgot about my Boruits. l once bought 4 of them, one was DOA, the other 3 worked for a short time.
Very poor reliability headlamps, those Boruits of mine.
Must not have ever charged a cell under 2v with my Opus. Never really paid attention. Have had it for over 3yrs and charged thousands, of 18650’s with it. Mostly vape batteries, at least 3 a day. I personally don’t like any usb powered 18650 chargers.
Thanks Robert
Are you saying The Nitecore UM20 that I have got not reliable for charging those batteries ?
Issue batteries won't get charged neither via headlight USB port nor via Nitecore UM20 and both methods via USB cables ?
Do you recommend this ?
I wouldn't expect to be a quality.
Could be non quality headlight killing those batteries ?
Thanks Henk4U2
Yes it is not quality headlight but switch looks to me okay
Which issue?
Do you recommend XTAR over OPUS ?
Yes, thats what I’m saying. “Problem batteries” The Miboxer C2-6000 is a nice two slot charger that can recover severely discharged cells.
I’d be happy to test your battery. I’m in Melbourne. not sure where you are.
The application you are using the 18650GA for is perfectly in the batteries capability The cells don’t have any protection to trip so I am going to guess they are fakes….
BTW, that headlight is running CREE XM-L2s at max of 10w each, likely less. Your two cells should be able to handle that easily. I’m speculating here but max amp draw should be around 7.5-9A. That headlight isn’t putting out anywhere near 13,000 lumens. Probably around 3,000.
The Sanyo NCR18650GA is an excellent middle discharge cell with excellent capacity. I have about 12-15 of them running various lights, lanterns and one power bank. They have excellent life, low sag and perform as claimed. Some of mine are well over 1.5 years old seeing regular use. They are a reliable cell which makes me speculate again yours are fakes. Counterfeit cells are big business nowadays. The good ones can fool the most thorough inspection so a good tester of capacity is about the only way to tell unless externally there is an obvious flaw (Bad wraps, codes dont match up, etc).
The genuine NCR18650GA cells have a slightly raised positive so there would be no need to offer a button top (Clue #2).
Just my $0.02.
This Liitokla “engineer” charger can be had for under $20 and is worth every penny. It can measure capacity and internal resistance pretty well.
LiitoKala Lii-500 Lithium And NiMH Battery LCD Smartest Charger
Where these left in the head torch for any amount of time before you found them dead? I bet it was a parasitic drain that has run them down to zero. This could happen relative quickly especially if the batteries where near flat when you put them away.
YOU can bring them back, but whether you SHOULD is a whole other story. You may of even gone into negative charge if they were in series.
