If Sofirn is listing them on Aliexpress, I hope we can get some before they sell out. Or have they allotted BLF a quota?
The interest list is still under 1000, and there will be 2000 made with Yuji leds, so they will not be directly sold out.
And if you do not neccessarily care for high CRI, if this light sells out quickly, no doubt Sofirn will make a low CRI version (with more light and narrower beam) at some point.
I have just asked to Sofirn if will be possible to buy the (single) driver of the new C01.
I see a lot of interest in this small keychain, Yuji LEDs are very much to blame. Recently I bought some Yuji Leds in Mountain Electronics but they are already sold out.
LOL, to make this light feel a bit more collectible, no pressure of course :
Barry made it clear once more that these 2000 lights will be the last with Yuji leds because, according to Barry, these leds are really discontinued.
Today 300 pieces of the black version will be sent to the anodisation factory. They want to make the C01 available during the 11-11 sale. Sounds ambitious to me but I have no idea how things are working over there.
So any idea what the plans are after the Yuji run?
Here’s a beamshot at 30cm from wall, bit from the side so I could use the bookshelves to place the lights on. Top light is 3200K C01, middle is 5600K C01, bottom is my Led Lenser keychain light modded with 45 degrees 5600K 5mm Yuji led. The tints and brightness look fairly accurate in the picture. You correctly notice that the bottom light is not 5600 Kelvin, it appears 5100K (middle I measured 5600K and top is 3200K, so the C01’s are spot-on).
Djozz, did you do a spectrometer test on these? Sorry if I missed it.
I have the E01vn with the 3200k Yuji and I like the tint on the SST-20 3000k 95CRI much better. So I just want to see how it compares. Wondering if Sofirn can offer a more expensive version with the SST-20.
That would be a different flashlight. The C01 uses 5mm DIP leds and that makes the construction very simple and robust. Using SMD leds requires a construction with lens, optic, ledboard, shelf etc., it may be that Sofirn makes a AAA twisty like that but it will not be a C01 but a new flashlight type.
I probably have posted spectrometer results somewhere in this thread, but I did them again for you.
Here’s a comparison between 3000K SST-20 (spot from Carclo 10507 TIR) and the Yuji 3200K (from C01, in fact an aspheric beam). So because of different optic not 1:1 comparable but it is how both leds are often used in real life. There is not a huge difference apart from that the SST-20 is clearly warmer tinted, I see no tint parameters which are known to displease people, I expect both to be as good as indistinguishable from an incandescent lightsource.
The Yuji leds are always dim of course, that can have an influence on the experience too.
C01 with Yuji 3200K 95 CRI led:
E2L with 10507 optic and SST-20-W 3000K 95CRI leds:
how is the list ever gonna be made and be accurate from 49 pages ? it will take hours to get everyone logged and taken care of wont it? seems like its gonna be a huge task .
That’s pretty much how BLF group buys go, and somehow it still works. The list is maintained in Post 287 and is up to date through last week.
Also, it’s been suggested that in this particular case (probably because the light is cheap and getting a lot of interest) the list probably won’t be used for direct online purchasing and might not matter very much at this point. Rather, the list is to gauge interest, and we might get a coupon code or something to make the purchase on Aliexpress where it’s already listed (as unavailable for now).
Thanks Djozz. Wow I’m surprised the Yuji in the C01 has a DUV of -.0037 making it even rosier than the SST-20. Im guessing it’s a different batch of Yuji emitter or the glass making the C01 so much rosier than the Yuji in the E01vn. Comparing the Yuji in my E01vn to other 3000k lights, I’m sure it has a positive DUV because it appears noticeably more yellow.
Now I’m interested in this. Please put me down for 3! Thanks.
@SKV89, you may have been unlucky with your particular Yuji led. I have six of these leds in a nightlight, very low driven btw, that may have an influence, but there is some tint variation among them. Here’s a picture, the tints are not reproduced very accurately but you can see that not all tints are the same.
I see a lot of new posts and quantity updates. Looks like I’d better get the list updated tonight!
There’s also tests here by staticx57 of both color temperatures, in 45 degree versions, presumably from a different batch, although he didn’t report DUV or provide a chromaticity diagram.
It is clear that I live on my BLF island, I had seen your test in the first post of the thread but not the spectral data later in the post
But I need to see the colors first to confirm my order and Maybe order more depending on the colors (if I like them)
The colours are the same red and blue that Sofirn uses in other flashlights. But to know how they really look is almost impossible from pictures, they differ depending on who took the pictures with what camera, and what monitor you watch them on. And no camera will get them exactly how they look in real life.
That said, this picture I found of the Sofirn SP10B gives the blue pretty accurately on my (HP 1740 on standard settings) monitor, the red SP10B is not correct, a bit too cherry in this picture, the actual colour is closest to the top part of the red S2+ in the same picture (the bottom part has more yellow from light reflection from the wooden floor, this is absent in the “Sofirn red”.
If Sofirn does their own Sofirn colours as announced, you are not getting more accuracy than this, also not when actual colour samples of the C01 arrive (which will not be this or next week from what I gather).
OK I have ordered my trits and magnets. Hope this works out…
I hope too, the magnet size for this light is not yet tested in practice, I ordered some of the right size at Fasttech many weeks ago but they have not arrived yet. Still think it should work.
Up my order to 2 of each.
link to djozz tests
1 × 3200K red please
link to djozz tests
The list is here:
http://budgetlightforum.com/comment/1355666#comment-1355666
I’m not an expert in automation but I think it should be possible to generate a PM to all people on the list with the how-to-purchase information.
link to djozz tests
I’d like to update my list preference from 1 light to 2. So 2 lights total. Thanks!
link to djozz tests
There is no glass in the C01 btw
link to djozz tests
Makes me nervous to see 7 orders on the page, and “Sorry, this item is no longer available!” Someone please reassure me…
link to djozz tests
Please add 2pcs red
3200k and 2pcs blue
5600k. Thanks..:)I am interested for:
2× 3200k Blue
2× 5600k Red
Please add me to the list:
Black 3200
Black 5600
Thanks!
I'll purchase (1) of the 3200K, please.
Hi, I'm interested in getting four of these.
1x Blue 5600k
1x Red 3200k
2x Black 3200k
I’m in for 1x Blue 3200k and 1x Black 5600k.
link to djozz tests
I want 4 in 3200k now
2 black
1 red
1 blue
Nichia 219B
link to djozz tests
I would like 1 black, 5600 K.
My reviews:
ROFIS R3 Multipurpose light , ROFIS MR50
link to djozz tests
