But my caving days are mostly over, something has shifted in my head and I no longer have any desire to do this mad stuff, (frankly I get too scared, and wouldn’t want to be a burden on the rest of the team if I freaked out. I’ve had to deal with this in the past with others, whilst remaining totally calm, and it is was not easy.)
Seeing someone completely falling apart because they have got into a situation far beyond their ability to cope, is not nice.
Particularly if you are in exactly the same situation, but trying to hold it all together, and work out a way forward instead of extreme panic.
The military try to avoid this, with selection and testing. And the rules of command.
It’s a game for young people I think. Old and bold is not a good combination.
Great article. I used to be a caver too and can easily imagine the sick feeling in the pit of your stomach when things go wrong. Since we are on a flashlight forum, how did the lights hold up? Have you changed your opinions?
Breakdown for modern flashlights is very rare event.( If we speak not about armytek:)). In our expedition all lights worked fine. Main part of our team uses ZL, H03 is popular among newbies , some “oldschool “ cavers use something like Ignivi or Scurion.(if I understand your question correctly)
Thank you! I wasn’t aware of Robbie Shone. I had heard in Russia you can find some of the deepest caves… but I didn’t know it had the deepest. Are there many different spectacular caving opportunities in Russia? I wonder if one must decompress after going so deep because of nitrogen absorption, sort of like what happens in diving?
Sorry for late reply,
it’s easy to miss the message here.
Abkhazia it is not Russia actually, massif Arabica is located very close to the border )) Mountains there has unique geology. The deepest Russian cave is Throat of Barlog it is only 950m deep it also located in Caucasus.
There are many beautiful caves in Russia , not such deep as Verevkina or such long as Mammoth cave in US, but each has its own peculiarity and unique. You can also take a look at instagram of Perovo caving club it not have many photos but still )
There is no such large preasure differense in cave. 2km of air creates pressure like 2m of water. So of course there is no need of decompression.
I see it has red/green battery indicators for voltage, and in your runtime graphs the output drops off suddenly. Is this an actual Low Voltage Protection or the voltage dropping too low to light the emitters?
Also, does it give any warning as your voltage gets below a lower limit? (besides the red/green indicators)
I ask because I sometimes use them for a long time and taking it off to check the color of an indicator has always seemed counter to the idea behind wearing a headlamp. If not I’ll just get used to it. Nice to have different beams in one headlamp!
Thanks for any info.
There are 3 way to understand that battery is low.
1)Red indicator in buttons.
2)Dramatic decrease of lihgt compere to beginning level.
3)Manual battery check (3click from off)
But yes if you use it a lot you may forgot about headlamp at all, and then it can turn off suddenly. But I think it is better than annoying blinks as many others headlamps.
The light turns off at 2.75V so it has protection.
And several points I forot to add to review.
1)Current butch of Panda3 has good termal control not just stepdown.
2) Panda3 actualy has stabilisation usual to linear drivers except for hi modes.
3)Panda 3 is compatible with this optics from Ali
Got mine today, very nice.
With both emitters running the beam profile is all you could ask for from a general purpose light.
Buttons are on the small side and stiff. This will keep the light off when stowed and the UI seems to recognize this. No long-press for on or off is perfect.
Headband is too small around and crazy long over the top. I’ll check into a skilhunt H03 strap for this. Definitely worth the small extra expense.
So impressed by the dual output, it’s the best of both worlds and I’m hoping for a handheld with a similar configuration.
Wouldn’t mind a lower low but I have enough headlamps that I can choose the right one for different applications This light goes in the Adventure Light category.
The dual output is so nice I’m looking at clip options for pocket carry!
