Maybe it is often problematic to support both NiMH and LiIon, but I think it should be possible and would be nice to have something like that that works. Also, as other said, some would probably buy it just because of this feature and use parts elsewhere
My Enogear SS AA/14500 driver fried the moment I put a 14500 in there so I can see the difficulty of supporting both. However, my Reylight Ti Lan and Sofirn SF14 supports both battery types very well and I love the versatility. I put in AA when I let my kids play with them.
+1
SKV89, what is the UI on the Reylight Ti Lan and Sofirn SF14? Do either have Narsil? Perhaps there are too many eggs in this particular basket, too many wants, not enough pocket to stuff them in…
I have a couple that work, too, but the UI is simple and the output is less than desired.
I only need it to work on NiMH AA cells. My grandsons would love this light, but they’re not ready for Lithium Ion batteries.
Perhaps they could make two offerings? One to run on AA (Alkaline, NiMH, NiCad) and the other to run on Li-ion? Then there would be a choice for those that would like to gift the light to non Li-ion users… That would be much easier for them to implement and they may well sell more total lights with the choice of power supply. Just a thought.
No those are rear clickies. Full click for on/off. half click to change modes. SF14 have no memory mode. Reylight you enable or disable memory mode. Very simple but both AA and 14500 works well though.
I think, Lumintop should also consider this version:
BLF GT M:
2S3P (6 pcs total) 18650 (OR a slimmer 2S 26650 version)
Net reflector diameter: 95 mm
XHP35 HI emitter
I think, this could be implemented as being just a bit more than half weight of the original BLF GT, and it would be a very practical thrower.
GT Micro could be a better idea with the Osram White Flat emitter.
interest list is open!
https://budgetlightforum.com/t/-/54245
I would rather see 2S 21700 because there are already a ton of similar 2S 26650 lights already including the new Jaxman X6 Hunter, Convoy L2 & L6, Thorfire S70, Sofirn SP70, etc.
Thing is that for me a general light appeals in any output, both low output and high output lights have their use and I accept and appreciate less output when the light runs on a safe NiMh battery.
But throwers is different, they must throw really well to be attractive, regardless the battery chemistry. A micro-GT modded with the best current throw led, the Osram KW CSLNM1-TG, on a NiMh and the best boost driver available, will still make under 50 kcd. My sk68 mod with dedomed XP-E2 from 4 years back does that too. While that same micro-GT with a 14500 does 130 kcd, which is impressive for such a small light and immediately attractive for me.
(admitted, I have no grandsons yet and my 8yr-old thinks me and my hobby is a bit silly)
I’m not really impressed by the battery life a FET on one of those entails. Since it won’t be AA compatible, I’ll just stick with a 18650 light.
how much runtime highest on a 1000mah cell then ?
If there was a 2 or 3 AA extension for this I would be all over it!
Aye! Put me on the list!
Bummer on no AA support, but will be interested if that becomes an option in the future.
you need to enter there to participate!
. this is the (derailed) discussion thread ;)
Wait, What? Did I miss something? They’re putting the Micro on Rails? A Rail Light? Cooooool!
Consider the thread re-railed.
[M4D deal ALIVE] Lumintop GT micro
Any idea if these will have a true neutral emitter (around 5000K) , or will they go with the warmer 4000K again?
Oh,oh . I think Dales startin a rail light dream next !
