[Available again! - BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED
Which shipping method did you choose? It’s kind of odd that nobody in the States has seemed to get their C01 yet, but somehow you got a light, albeit the wrong light, in 18 days. Mine’s still in China!
Superlube rates their products “Excellent” or “Good” with everything:
Thank you for that link hank. I have used SuperLube exclusively on all my light threads & O-rings for many, many years & never had a problem. Never a gummy O-ring in all that time either.
BUT, I had never seen that chart you linked to!!
It does seem to cover it all… :+1:
What kind of monster did they create in that PDF file?!
That face is some nightmare fuel for some people.
Ew. I intentionally didn’t link to that uglyface.
So it seems to be compatible with everything EXCEPT silicone rubber. Isn’t that exactly what the o-rings are made out of?
Sho’ nuff, a lot of O-rings are made from that.
I should’ve said almost everything: "O-ring" silicone rubber - Google Search
Wow: Silicone rubber (FMQ, PMQ, MQ, VMFQ, V - Google Search
but O-rings can be made of lots of other stuff: O-Ring Material Chart Rubber Selection Guide Quick Reference
Here’s a caution and recommendation:
Pardon the digression.
:open_mouth: Dang, I missed that when looking at the chart. :person_facepalming:
Silicone rubber (FMQ, PMQ, MQ, VMFQ, VMQ) / NC
But…… Seeing SuperLube is all I ever use, I cannot imagine not having used this on Silicon O-rings at some point. So I will not be changing anything. SuperLube has worked flawlessly for me since my first AA Maglite till now. That is a lot of years & a lot of lights. :wink:
If it ain’t broke, don’t fix it…… that is my theory. :+1:
BUT, I also am gonna get some O-rings I know for certain are made of ’Silicon’ and see what happen when I use SuperLube on them. :wink:
I’ll report back……. :smiley:
COMPATIBILITY CHART
Super Lube® Silicone O-Ring Grease
Polymer (plastics) Constant Strain Tensile Testing / Rating
Acryonitrile Butadiene Styrene (ABS) / E
Cellulose acetate (CA) / E
Polyamide ¶ (Nylon) / E
Polycarbonate (PC) / E
Polyethylene (PE) / E
*ultra high molecular mass (PE-UHMW) / E
*low density (PE-LD) / E
Polyethylene-/polybutylenetherephthalat (PET / PBT) / E
Polyoxymethylene, Polyacetate (POM) (Delrin) / G
Polypropylene (PP) / E
Polyphenylene oxide (PPO) / E
Polyphenylene suphide (PPS) / G
Polystyrene (PS) / E
Polytetrafluoroethylene (PTFE) / E
Polyurethane (PUR) / E
Polyvinylchloride (PVC) / E
Thermoplastic elastomer (TPE) / E
Elastomer (rubber) / Rating
Acrylic rubber (ACM) / E
Buna S / E
Butyl (IIR) / E
Polychloroprene rubber (CR) / E
Chlorosulphonated PE-rubber (CSM) / E
Ethylene-propylene-diene rubber (EPDM) / E
Fluorinated rubber (FKM) / E
Natural rubber (NR) / E
Neoprene / E
Nitrile (NBR) / E
Polyurethane (AU, EU) / E
Propylene-tetrafluorethylene rubber (FPM, FEPM) / E
Styrene-butadiene rubber (SBR) / E
Viton (FKM) / E
RATING KEY
E - Compatibility Excellent
G - Compatibility Good
NC - Not Compatible
Sorry, I couldn’t figure out how to post the chart so I had to improvise by ’copy & paste’. :person_facepalming: … Oh well…. :smiley:
I use Super Lube 51010 in a precision oiler, no problems with any of my flashlights.
Does anyone else remove their o-rings and lube under them?
Hmmmm, I don’t…. but I actually never thought about it either. :+1: It sure couldn’t hurt, I think I’ll give it a try & start lubing those O-ring grooves.
I do, maybe every other time, thinking it might help seal out moisture and water.
OK, here is the deal on the SuperLube confusion……
THIS is the SuperLube I use on my lights for threads & O-rings. It will not harm Silicone O-rings, it is a Synthetic based grease. (see below \ )
THIS is not the SuperLube I use. It is a Silicone base O-ring lubricant. It is not suitable for Silicone O-rings. ( see below \ )
SuperLube website link
Regarding stuff to grease threads and O-rings I use Nyogel 760G, I bought a small tube at NKON.nl: https://www.nkon.nl/flashlights/armytek-flashlights/armytek-nyogel-760g.html
Edit: More info on flashlight lube and grease at CPF: http://www.candlepowerforums.com/vb/showthread.php?126645-Comprehensive-Grease-and-Lube-Thread
However lubing the threads and O-rings of both my Fenix E01 and Sofirn C01 does not dramatically decrease stiffness… It does make the twisting slightly smoother though.
From defloyd77:
[/quote]
Here is the tracking from Aliexpress,it surprised me more than it did you.That is one reason I didn’t think the sc31 had anything to do with my sc01 order.I thought that I bought the sc31 during a flash sale then forgot about it!
I ordered 2 5600k sc01’s Sunday.As for shipping,I’m getting whatever the free shipping is.
Delivery
2018-11-28 14:22:00 [ US17331 ]
Out for Delivery
2018-11-28 09:09:00 [HANOVER,17331]
Sorting Complete
2018-11-28 08:59:00 [HANOVER,17331]
Arrival at Delivery Office
2018-11-28 01:18:00 [UNITED STATES OF AMERICA ]
Arrived at USPS Facility
2018-11-28 00:47:00 [HANOVER,17331]
Departed USPS Regional Facility
2018-11-27 23:36:00 [HARRISBURG PA DISTRIBUTION CENTER]
Arrived at USPS Regional Facility
2018-11-27 16:30:00 [HARRISBURG PA DISTRIBUTION CENTER]
2018-11-27 03:25:00 [WHITE PLAINS NY DISTRIBUTION CENTER]
2018-11-27 02:35:00 [STAMFORD CT DISTRIBUTION CENTER]
2018-11-26 06:33:00 [STAMFORD CT DISTRIBUTION CENTER]
Arrival at Sorting Center
2018-11-25 18:48:00 [UNITED STATES OF AMERICA USUSJFKF ]
Processed Through Facility
2018-11-17 04:29:00 [CHINA,GUANGZHOU EMS]
Acceptance
2018-11-16 19:45:00 [CHINA]
Posting
2018-11-16 19:45:00 [GuangDongShengGuangZhouShi 51001020 ]
silicon =\ silicone
But y’all knew that.
2018-11-20 23:10:00 GuangDongShengGuangZhouShi 51001020 Posting
2018-11-23 09:51:16 GuangDongShengGuangZhouShi GUANGZHOU Despatch from Sorting Center
Haven’t had any updates since 23rd.
Ordered mine Nov. 10th. Still in the “Origin Post is Preparing Shipment” stage.
Oops… :person_facepalming: . Fixed it. :+1:
:wink:
