Oh, big big big plus in my book, the ~1buk deep-carry clip for the S2+ fits this light perfectly, as if made for it. Also, the anodisation is a perfect match, too, no gloss vs matte conflict or anything.
I hate clips in general, especially when the light rides high with almost a third of it sticking out of a pocket, but this DC clip lets the UT20 ride niceânâlow, almost nothing sticking out.
For dog walking pretty much every light will do. So I suggest something cheap but not too cheap.
Boruit RJ-02 on a good deal? OK, It will work but for some people that will be too cheap.
If the friend is a quality oriented I suggest Zanflare F1, looks quite like a premium product yet has a budget price.
Iâve been beating on the same â02 since I got it, and itâs still going strong. Saw it was âcheapâ, ordered a bunch as âdisposablesâ, yet the first one is still chugging away just fine. I wouldnât dismiss it as low quality or anything. Sure, it doesnât have a fancy emitter and everythingâs on one PCB, but it still⌠works.
Yeah, where we live âdog walkingâ and âfleeing outdoors during the earthquakeâ are both routine uses one has to expect.
So reliability counts. USB charging is a nice convenience.
I second the Nitefox UT20. A couple other options are below:
Sofirn SP32A
Zanflare F1
Rofis MR30 is awesome at 1600 lumens and can be had on Amazon for $30.
I own all these and can vouch for each one.
Iâve had a BD06 for some time and find that itâs a solid, quality light. It may not be the most impressive in output (about 1000 lumens) but with a quality 26650, itâll run for a looooooong time. Mine had the upgraded driver and I had it set up in a few different ways. Itâs a nice feature. The charging system snaps over the switch and works fine. I never measured it, but itâll do the trick, It will take some time to fully charge a 26650 though. The switch is pretty beefy and takes a bit of force to engage. Overall itâs a nice value.
I have one each of the Convoy BD01, BD04 and BD06 lights. Theyâre nice lights, built to Convoyâs usual good quality, all with Biscotti firmware and all available with your choice of LED colour temperature.
The only snag is that USB charging requires a special adaptor that snaps on over the switch - if you lose the adaptor, you canât charge the light.
maybe i could to a full test of the lights that i have and charging sources i have. now you have sparked my thoughts in doing a full light charging & charger test comparison review when i can get the time to run some more tests. I have done some as mentioned above by Hank. Some of the lights i have tested were the Klarus G20, Blitzwolf BL-LT5, Zanflare T1, Olight S1R, S2R, Nitecore HC60, DX80, and others. I did charge voltage & amp tests using various wall chargers, car 12 volt chargers, off-grid power banks, portable solar chargers, power banks, and others.
