If i had one i would give the charger system the full range of testing. I have tested many different types of lights, lanterns, etc and so far the best two lights with built-in chargers i tested that would charge from all the different sources i benched them on, is the Klarus G20 and Blitzwolf BW-LT5 lantern/powerbank light. (both these would charge from every source i tested them with.
maybe i could to a full test of the lights that i have and charging sources i have. now you have sparked my thoughts in doing a full light charging & charger test comparison review.
Sure ;-) ► click here ◄ (just make sure you choose the "EN" version on my sharepoint for English language)
To be honest, it's "only" the NarsilM manual, so the first page where Sofirn states some information about it, where you can find more resources about NarsilM and the BLF Q8 etc. is missing. I asked Sofirn if they allow me to publish the entire manual but so far they did not want me to because it's not being sold on Amazon yet.
I’ve been using this light for one day. I like it but I think it could be improved a lot with just 3 changes.
My Sphere shows 5400lm stock with 30Q
I just don’t like three things:
-No lanyard attachment. The light is heavy and easy to drop, they should try to put an attachment for a lanyard wherever they can. Or just a thread for a tripod mount like the Q8
-Usb cover protrudes a lot, it should be recessed and harder to open by accident
-Leds choice. I don’t like the xpl2, ugly tint and lots of tint shift. This light should use the same xpl hi as the Sofirn Q8
I was wondering about the lack of lanyard attachment and think that I might try this one again if I can find the directions again. I used a knot around my Zebralight headlamp that works well. Unfortunately I completely forgot the name of this knot, but someone might know the name if they take a peek at the picture below,
I agree with the lanyard attachment, it is one of the things that I reported back to Sofirn about the prototype. You can see that in the current design is would not be easy to find a good spot for one so I understand why they left it out, but they may had better tried a bit harder.
I have not used my SP36 in a camping situation outside, but I can see that the USB-cover could suffer from real use (I did rip the USB-cover off my EagleEye X2R recently).
The XP-L2 is the only current led that will get them over 5000 lumen in this flashlight so that will sell, simple as that. And I must say that in the SP36 this led has a better beam than in some other lights that I tried it in.
Perhaps the Samsung LH351D would perform well? I’ve found them making big lumens in a D4S quad, so they should do well here too. Just a thought, lot nicer beam and tint anyway.
Edit: Well rested my D4S just tested at 5961.6 lumens with Samsung emitters.
