Yes, they do not rotate.
This is the same for lenses, record reflectors, and forward-facing reflectors.
I will literally upload a video right now for you to see.
Seriously, go try it yourself if you don’t believe me.
This is just simple optics.
Same for lenses and recoil reflectors.
It inverts the image (left side of LED is projected on right side, etc) but nothing rotates.
You’re right that’s obviously a reflector beam. But that image of the LED you are referring to is not from the reflector; that is imaged directly from the LED. It’s completely independent of the reflector. It’s like the spill of the flashlight, not the beam. Move the pinhole near the outside edge of the reflector and you will see the images that actually make up the beam. You don’t really see it in your video because you only move the pinhole around close to the center where there is no reflecting surface.
The pinhole was moved from one edge of the reflector all the way to the other edge. It’s only a 36mm diameter reflector.
You can see the hotspot leaking from around the piece of paper near the end of the video, and you can see how the radius of that spot is about the same as the distance from the square to the center.
If it was direct light from the LED itself the square would be moving outside of that radius because it would be exiting at an angle.
Also the brightness of the square would be much dimmer, like the spill brightness, not anywhere close to the brightness of the hotspot.
Seriously, just try it yourself.
I don’t know why you have such a hard time believing it.
Well this is like one of those divisive issues where each party is convinced he’s right despite the other’s argument. Luckily it’s one of those situations where it’s not a matter of opinion and only one of us is in fact right. I’ll give it to you that you are very sure of yourself even when you are wrong. I don’t know if that’s a good or bad thing, but it might serve you well in life.
I don’t think you did actually move the pinhole across the whole reflector. Try it again farther away from the wall and you will see the two different images of the LED that make up the beam and the spill. The image you are talking about that didn’t rotate is just an image from the LED formed by the pinhole camera. When you are farther from the wall you will see that it is in fact the spill and not the beam.
Check out this classic thread. This is where I learned of the pinhole demonstration and there are some nice pics of some demonstrations.
Edit: I admit I don’t really understand the details of why the image rotates. While moving the pinhole 90 degrees (like from the north side to the east side of the reflector) the image of the die rotates 180 degrees, which is not what I expected. On the bright side, this is some more “simple optics” we can learn.
Well shit, you were right.
I was looking at the light directly from the LED and not from the reflector.
Moving farther away made it clear that there were two die projections, one from the LED and one from the reflector.
And the one from the reflector does indeed rotate.
My bad!
Weirdly enough, it does not happen with my syniosbeam.
Even though it is still a reflector and simply the other half of a parabola, the LED is always right side up.
I guess it does make sense if you think about it, if you put a mirror behind something and move it around the object is always going to be upright.
If the mirror is between you and the object then it will rotate what you see depending on where the mirror is, like if its on the ground, or on the ceiling, or to the side.
Which driver did you go with? I was planning on using the l2 as my 1x1mm host, instead of the l6, just because its easier to get the l4p driver working right in it. I’d I could get the eswitch working in the l6 with 3v at about 5a, that would be way better, and slightly larger reflector.
Texas avenger 3 channel LDO modified to 1S removed LDO and with Andúril firmware I setted ramp max where a fully charged battery making the most lumens. Removed spring bypasses, using long 22 AWG wires to led Not using turbo because it give too much amps to led. Reflector bottom need grinding to fit wires and not using centering ring.
Thanks. Pretty close to what I figured, but was hoping you found something eswitch and regulated. I was hoping to not use extra external resistance to keep the current low.
Ill try the first one in an l2 host with my inbound l4p driver and see what it does, maybe even measure with the l6 reflector loosely fitted.
Since they are rectangular instead of square, maybe a headlamp or bike lamp using a wide angle lens? The beam would then still be super tight in vertical orientation and super wide horizontal. :sunglasses:
They are not really very rectangular, it’s pretty close to square.
In a reflector it still makes a round spot, so have anything noticeably wider than taller you would need a lens, and even then it’s still pretty square.
