Why a 5 lumen high “moonlight” mode Acebeam? If you want to make a good backpacking light it should have modes below 0.1 lm, 5 lumens is waaay to high for preserving night vision.
A secondary green/red emitter would totally ruin the idea behind this light and raise the cost significantly. Would it have a decent moon, eg. 0.1lm or lower it would be a competitor for the classic Petzl headlamp, but now it’s not.
I can light my entire bedroom with the ceiling bounce of the 0.07 lumen mode on my ZL. It can also reach across the longest part of the upper floor of my house with a usable amount of light. When your eyes are dark-adapted (and you want to KEEP them that way) 5 lumens is far too much and much less it required to see fairly far.
So having a Zebralight means you are forced to use the 0.01lm mode? Even 0.5lm is quite a lot of light if you want low light or want to be discreet. For me 0.01lm is more then enough for navigating through dark rooms an my eyes aren’t even that healthy.
My favorite as well for the price/feature set. This light needs to be priced right for me (somewhere) with high CRI being my only differentiating feature, the TH20 being significantly less expensive and its ability to ramp down to 1.6 lumens.
Way too much competition out there for these lights to be inching up in price without the desired features as they have been of late, imo.
Honest comparisons here are the only way to stop this nonsense as somebody has been doing of late to at least snap the world back in to reality.
MSRP Price 34.30 USD (on Acebeam website):
is this for regular version, for high-cri version, or both?
Acebeam: please do add a moonlight mode (<1 lumen), or even better firefly mode (< 0.1 lumen). This will broaden the appeal of the H40 to a wider audience, while it will not deter people from buying it.
Is there more info on how the rotary interface works, e.g. magnetic?
I like the idea of rotary interfaces, however the specific implementation on my Imalent HR20 feels quite fragile…
Both a 14500 Li-Ion cell and a AA NiMH cell have about the same overall energy when delivering low current, so you would expect them to have similar runtimes if lumen output is the same. Therefore, one of the following is happening:
1. Light output on NiMH is actually lower than on Li-Ion
2. If light output truly is the same (5 lm), then the above runtimes are wrong.
3. If light output truly is the same, and the above runtimes are correct, then this driver is wasting a lot of energy when running on lower mode when using a Li-Ion cell.
Looks like a great AA headlamp. I have the Acebeam H30 and while I like the 21700, high output, and form factor, I don’t prefer the CW tint and don’t need the green/red emitters, which I’m planning to swap out in the future for Nichias or Optisolis 2000k and 5700k.
Also what tint bin is the SST-20? I hope it is not above the BBL again. I have the Acebeam EC65 219C version and I don’t like the greenish tint so I won’t use it until I swap the emitters. Otherwise it would have been a great 21700 light.
The website seems to indicate a ramping mode of 20-230 lumens, with an “ultra” low of 5 lumens and a turbo of 350/1050 lumens or 250 lumens. It also mentioned ramping controlled by a single button. So I guess no dial.
