Probably not any that are on the market in stock form. But I really don’t know. Acebeam has the X70-GT that is fan cooled and has a top output of 90,000 lumens (for a little while). It could possibly do fairly well with 20,000 lumens. It would run out of power long before three hours, though. Modern LED streetlights produce tens of thousands of lumens for all night long, so the heat issue has to be solvable, even without active cooling.
Edit: Just now read the thread about the Acebeam X70-GT saying it is fake. Sorry. :person_facepalming:
Sorry, the Acebeam X70-GT turns out to be a fake. But, it is still definitely possible to do something like 20,000 lumens for three hours if heat is managed properly and power supply is large enough.
How about a series of grow lights with different wavelength emitters to get the proposed spectrum? They could be modified to run off an external battery. Size might become an issue though if like 6 of them were needed.
Thinking about it now, Tom Tom could be right. Another type of bulb could be better since there would be less need for thermal considerations. I really don’t know much about the light spectrum though.
How remote is the location where you will use this light? Reason I ask is if it is remote, 20,000 lumens seems excessive.
I pulled in at a remote fuel stop in Outback Australia. That place was crawling with flying insects and it wasn’t that brightly lit but as it was the only light source, insects were attracted there
Or you could just stand me in the middle of a parking lot. For some reason bugs just love me. I’m like sugar to them… :confounded:
There’s a Nitecore Big Honkin’ Light Panel that could probably do the trick, but it’s pricey. Probably need cool-white or the usual colors that are bug-magnets.
What color were you looking for, specifically? Any idea? Or just Whatever Color Attracts Bugs?
Bugs are very attracted to UV (which is why a lot of fly traps use it to attach them) but that can be dangerous to human eyes.
If this is to be used in a dark area at night then a regular white LED (which emits over a wide range of wavelengths) should be good enough to attract a bunch of insects.
A COB LED is ideal for this use case because you don’t need to have a ton of smaller LEDs, and if you get a very powerful COB and drive it at like 50% you can get very high efficiency (150lm/W or more)
The gold standard is a high powered mercury vapour bulb, 125 watts upward, but these have been banned in the EU for over 3 years now, so old stocks are getting low here.
