Also, an update on the drivers. I have built them now but bumped into an issue for clicky switch lights that I’m trying to solve without new driver design. Doesn’t effect E-switch configuration though.
Also, still working on putting together the firmware. I’ve implemented support for quite a few of the suggestions here, and it’s required me to re-write how my firmware works to support these options, so the suggestions have been appreciated! Keep ’em coming.
Keep it simple, or as much as you feel fine keeping it. I understand certain people may be accustomed to a lot of driver features but that poses extra work which could pose a serious development hurdle which the majority of users won't really care about. I prefer it Haiku style, it already annoys me grabbing a C8T/C8F and needing to go to Sofirn's website or this forum with my smartphone because I do not @#$%ing know how to switch the group modes or whatever.
Ahh, but the whole point of this giveaway is to get suggestions that I like, and then see if I can make them… for myself…
I’m not making these drivers for the masses, I’m making them for me… This thread is only about a driver development junkie looking for a fix, and paying for product with a few drivers
Wellp, optimize then access and operation of functions in order of frequency of use. A well scaled mode set and battery check already does for me. Plenty of room for other's suggestions. O:)
Woke up today and got idea of how to avoid seeking the button while avoiding turning on when it’s not needed.
But it’s one of those things that user won’t figure out by themselves within 2 minutes of playing with light. A bit of hidden complication.
The idea is: implement a simple twisty / reverse clicky UI. Unlike most clicky UIs - don’t turn on when the power is on but upon short disconnection. Bonus feature: add more than 1 shortcut like that and or allow more control of the light with just a clicky.
So you have a lighted tailcap that is on while the light itself is in sleep mode? I’d see this more of a lockout feature that only requires a short tap to unlock. I could certainly implement that as one of the lockout modes.
That comment was a followup on Driver giveaway: Constant current 17mm drivers, winners (finally) announced, post #2. - #69 by Agro
Unless I expect that I will use a light again soon I turn it off by unscrewing the tail to physically lock it out. I’d like to be able to turn it on by the tailcap only w/out having to seek the e-switch. As discussed, just turning the light on upon screwing back would be a disproportionate response as it prevents f.e. going directly to moonlight to minimise disturbance.
I believe that with dual-switch lights it would work the same - you normally have the light clicked off. You click it on. What happens? With a regular clicky-only firmware the light turns on. Quite a few dual switch lights do the same. But that’s just the unwelcome choice for e-switch only lights.
But user could click on and then make a short tap to turn on. That’s not something obvious but once you learn it - should be easy to remember.
And would enable basic operation with just the tail switch. Or just the tail cap.
Oh, so this case is for dual switch lights, not single switch clicky.
I basically have this done, just have to add it to dual switch configuration and have it as a setting. I would not make this default standard behavior but rather an option that can be enabled/disabled.
Just got back from more traveling, things have been still for a while but I’m back at it. Still working in clicky functionality. I have the major issues worked out but still doing stress tests. I really can’t stand issues that sometimes might happen, I wan’t full reliability on off time presses.
The initial issue is that the more pins I have outputting to the strings of regulators, the faster the OTSM cap is drained. 47uF was fine when only one or two regulator strings where on, but more and the OTSM functionality started to fail. Took a while to figure out what the issue was. I’ve gone up to 100uF and that issue appears solved but I am still working on the OTSM code for some circumstances.
I get the CN571x regulators from here: https://lcsc.com/ So far they have been nothing but fast and reliable. Gotta tip my hat to Schoki, he was the one who tipped me off about these regulators and where to get them
Sorry, not firmware related… just studying the driver design. But I was looking for your voltage dividers, but it looks like most of the resistors are for pull down or current setting. Am I missing them? Or does the 1634 have a fancy way of reading voltage?
There is a voltage divider on board, it’s 3K / 1K divider, you can see 302 and 102 marked resistors. I don’t use it for voltage measurement though, to read voltage on 1S drivers I use MCU VCC as voltage reference, then connect internal reference voltage (1.1V) to the ADC and measure it. Essentially I don’t need the divider, at least not one of the resistors, but as it is now I use it for OTSM power off detection.
I put in a divider in case it would of be use, like for future 2S versions. However, there certainly won’t be 2S versions. I just did a test with a CN5711 and a MT-G2 LED. They are rated for 6V but I thought perhaps the thermal throttling might save it, but nope, it fried with accompanying smoke signals just shy of 8V. They simply aren’t suitable for 2S.
