Ha Thijs, since the board is toast anyway, remove the driver and heat the head up to very very hot (not so hot as to decolour the ano) and see if the glue will give in.
Definitely worth a try.
After heating it up some more the board finally came loose.
But the new board doesnât fit, itâs too bigâŠ
So Iâll take the head to my work where I hopefully can machine the inside a little bit bigger.
It is much easier to sand a bit off the new board. I use a disc sander for that, but even by hand it should not take too long, you only need to go from 20 to 19 mm.
Ahahaha I like this
It would be nice to open such threadâŠ. Seriously⊠I think it could be very popular here.
Ah yes there it is
I got the new Sofirn SP33 today, they changed up the old version to the XHP-50.2 and made some small changes, biggest of which is the boost driver of course but also an Orange Peel reflector. Mine had a horrid beam profile, so I sliced and diced the 50.2 to not only clean up the aura but also warm it somewhat, it started out very cool white, almost with a lavender hue. After removing the dome, there was still a discolored greenish center to the hot spot so I made a different centering ring work and raised the reflector about 1 mm, not completely right but much better and I can live with it. I think itâs now making a little over 2200 lumens, pretty decent.
I had put an 50.2 in a Utorch UT02, sliced and diced it this morning before the SP33 came in so itâs been a day of cleaning up flip chip auraâs.
I almost sat down to do my first proper mod â two driver swaps on my older Convoy S2 and my single C8. Unfortunately I found out (thankfully ahead of time) that I need flux to make good solders
Glad I never found that out, I wouldnât have been able to do the 500+ mods Iâve done as I donât have flux nor have I everâŠ
You have trust in your skills, it works as a fine substitute
I never could solder until I started working on flashlights. Got the Hakko 888 station and some .031 Kester solder and it suddenly got much easier. Before you know it I was stacking 7135âsâŠ
Flux helped me a bit when i tried to use lead free as a beginner. Since i switched to leaded solder I dont even bother with flux. I dont care what it says it makes a sticky mess.
I may try lead free again now that i have a couple dozens mods under my belt, but maybe not. It just works
I use organic flux, the âwasher fluidâ-looking stuff. Works a treat. No idea whatâs in it, maybe M-stoff and water, who knows.
Wiring up some small resistors to eliminate the dreaded âhyperflashâ when using LED bulbs, and needed the Evil Third Hand to hold the wire and resistor against each other, sooooooooo precariously. Slightest jiggle, and they pull apart.
Wellp, a drop of organic flux to sizzle away, apply a blob of molten solder, and itâd flow nicely⊠but almost instantly skin-over and turn ugly. Needed a coupla more passes with flux+iron to get a solid (haha) connection without snapping apart.
Without flux, itâd turn butt-ugly and might not even be a good joint.
Then again, I was going easy on the heat, not cranking it up like I usually do. Didnât want to turn the wire-insulation into âbellbottomsâ (melting, pulling-back, and bunching up).
On, say, soldering a through-hole component on a peecee board, where you can press hard and get good heat transfer, the rosin-core in the solder is often enough.
Iâve always used lead free solder with no flux other than whatâs already in it.
Not that difficult to get a good solder joint, at least now that I have a good quality soldering iron.
Iâve always just used butter.
Eswitch wires on fet+1 boards are the hardest things ive run across and its prob cause i refuse to change tips mid project. The signal wires on L4P drivers are so easy and have huge durable pads.
Here's the Convoy L2 with 1mm White Flat hitting a white Van at 480m.
I havenât even owned extra flux for decades, although I soldered thousands of my self developed boards âprofessionallyâ in the first years of my business live, back in the 80s. There is plenty of flux in the middle of the solder wire, I just had to learn the proper technique. Not much different with unleaded solder nowadays.
Time for a quick one before I put the dinner on and the beers start to take effect... :-)
Added some 3K carbon fibre tube to the CRX SR4-Cu and an o-ring & CF stop to the end of the battery tube.
This covering gives a little buffer before cooking the hands with the light on full tilt :D
Copper, brass, carbon fibre & titanium construction
Quad Nichia 219C 5000K emitters
20mm Copper DTP MCPCB
20mm x 7mm solid copper heatsink
22mm x 2mm dual coated ARC glass
Green GITD glow bezel
Emisar D4v2 ramping driver
Copper, tritium & glass electronic tail switch
Lockout-able
Magnetic cell contacts
56, 2mm x 2mm magnets in tail
18650 cell compatible
Max 3400lm
Length â 97mm
Width â 27mm
Weight â 241g (with 18650 cell)
Nice addition, and good luck with the cooking. (Iâm off-duty, we are going out for dinner this year in an hours time ).
Merry Christmas!
