I use organic flux, the “washer fluid”-looking stuff. Works a treat. No idea what’s in it, maybe M-stoff and water, who knows.
Wiring up some small resistors to eliminate the dreaded “hyperflash” when using LED bulbs, and needed the Evil Third Hand to hold the wire and resistor against each other, sooooooooo precariously. Slightest jiggle, and they pull apart.
Wellp, a drop of organic flux to sizzle away, apply a blob of molten solder, and it’d flow nicely… but almost instantly skin-over and turn ugly. Needed a coupla more passes with flux+iron to get a solid (haha) connection without snapping apart.
Without flux, it’d turn butt-ugly and might not even be a good joint.
Then again, I was going easy on the heat, not cranking it up like I usually do. Didn’t want to turn the wire-insulation into “bellbottoms” (melting, pulling-back, and bunching up).
On, say, soldering a through-hole component on a peecee board, where you can press hard and get good heat transfer, the rosin-core in the solder is often enough.
I’ve always used lead free solder with no flux other than what’s already in it.
Not that difficult to get a good solder joint, at least now that I have a good quality soldering iron.
Eswitch wires on fet+1 boards are the hardest things ive run across and its prob cause i refuse to change tips mid project. The signal wires on L4P drivers are so easy and have huge durable pads.
I haven’t even owned extra flux for decades, although I soldered thousands of my self developed boards “professionally” in the first years of my business live, back in the 80s. There is plenty of flux in the middle of the solder wire, I just had to learn the proper technique. Not much different with unleaded solder nowadays.
Main reason for it is that I damaged the inside of the head a bit.
But I didn’t want to wait till Thursday I looked around in my workplace what I could use, then I remembered I have a Dremel tool. :person_facepalming:
So I used the Dremel with a small drum sander the enlarge the inside of the head and removed the damage. Also sanded the board a bit smaller with a nice bevel on the underside so it will sit flush.
And, after replacing the springs for those beautiful springs from Blue, the light is assembled and is working. :partying_face:
Used the small spring on the driver and the big one on the switch. Have to say that the springs are a but large, you’d need to use some force to put the tailcap on.
With the LH351D’s there is a slight hint of green in the beam (as reported by many others), compared to the XP-G2’s 5500K that where in there before (RIP! )
I don’t find it to be that bad, probably not noticeable in real life use.
Extra flux really helps my rework, though more recently I’ve found that adding a bunch of fresh solder (and the embedded flux) works well too, and with the added bonus that it can heat multiple legs at once on chips like the 7135.
Same story in my case but it started just a year ago. My first mod was replacing a ref in S2+ with a shaking hands. A few months ago started soldering and that gave me the ability to assembly a flashlight from components which is great. I learn how the things work but there is still a lot to get know. I appreciate this forum a lot thanks guys!
Changed the Driver of my eagle eye X7 with Luxeon MZ 90CRI from original with resistor mod to Biatro Driver from Lexel.
Got 1800 Lumen instead of 1200.
and with bypassed switch and spring I got 2200Lumen.
Dang a year in and you’re already soldering QFN16 packages? It took me years before I was willing to try QFN parts and even to this day I still have a relatively high failure rate on the first reflow (probably 50% need a second reflow). What’s the pitch on that part?
- 22mm AMC-based driver with slave board. 26 * AMC7135 for around 9,1A
- Bypassed springs
- soldered a copper foil between led and terminal-pad of mcpcb for a better focus
- sanded down a centering piece and opened it a bit. Before opening it is getting lose due tu the centering piece and had bad contact to the mcpcb, so the led turned a bit blue.
addad a second O-Ring (one on each side of the glas) to keep the reflector down due tu the sanded centering piece.
Did some tint mixing with newly arrived Luxeon V2 5000K from DigiKey. I’m running out of lights with bad LED’s to swap but I picked my 1st batch D4. I also flashed the latest Anduril on it since I had it apart.
Before:
D4 VTC5D Nichia 5K 80CRI 3,650 lm
After:
D4 VTC5D L1V2 4K+5K 4,207 lm @ ~19.xx amps
D4 VTC6 L1V2 4K+5K 4,180 lm
Luxeon V2 4000K+5000K+dirty TIR
The hot spot is much more defined and throwy. The star pattern thanks to the non-rotated 1st gen MCPCB is even more obvious now. The tint in the hot spot is pretty good, not at all green like the 80CRI Nichia 5K. There is a bit of a pinkish/purple tint in the spill though. I think it’s partly due to smooth narrow optic and partly due to what I assume is both of these LEDs being below the BBL and now that they are mixed they are even lower.
