I’m thinking o f getting a D4s ,I like the XPLHI 6500k version of my D4 & I’m thinking of getting that in the D4s but what’s the difference between it & th SST-20 6500k version ,I know it has more throw ,do you sacrifice flood? Is the tint the same? Is it more power hungry?
It would be nice if we got a side by side pic of the tints and beam shape for each of the different emitters. I’d bet it would help people get off the fence and order.
But hiding flashlight in your mouth before diving into muffin is very rewarding.
Or even just the SST-20’s!
It’d be really nice if it was standard for flashlight companies to include a “cd/lm” metric for every model and every emitter type. This goes a long way toward giving people a good idea what the beam is like. For example, is it a 2 cd/lm flooder, a 8 cd/lm EDC light, a 35 cd/lm compact thrower, or a 200 cd/lm dedicated thrower?
Pictures or it never happened… just sayin.
Happy new year with Emisar D4S in one shot no photoshop:
Nice Zozz!
@TK
Emisar D4S
OTF lumen output / candela / reach at start-up / cd/lm (2018-12-03)
XP-G2 S4 : 3300lm / 40,000cd / 400m / 12.1 cd/lm
Nichia 219C : 3000lm / 20,000cd / 282m / 6.7 cd/lm
XP-L HI : 4300lm / 45,000cd / 424m / 10.5 cd/lm
XP-L HD : 5100lm / 27,000cd / 328m / 5.3 cd/lm
SST-20 6500K: 4200lm / 58,000cd / 481m /13.8 cd/lm
SST-20 5000K: 4000lm / 55,000cd / 469m / 13.8
SST-20 4000K 95CRI: 3000lm / 41,000cd / 404m / 13.7 cd/lm
SST-20 3000K 95CRI: 3000lm / 41,000cd / 404m/ 13.7 cd/lm
is the sst20 5000k greenish tint wise?
In order to pick the right firmware for YOU, maybe there should be a survey.
“When I press the button, I want the flashlight to respond immediately: (please circle one)
(AGREE STRONGLY) (AGREE SOMEWHAT) (NEUTRAL) (DISAGREE SOMEWHAT) (DISAGREE STRONGLY)
When I adjust levels, the light should not flash or flicker:
The light should remember my last-set ramp level, even if I have used a shortcut to moonlight or turbo:
(AGREE STRONGLY) (AGREE SOMEWHAT) (NEUTRAL) (DISAGREE SOMEWHAT) (DISAGREE STRONGLY)”
and then the script compiles it!
How long til the flashlight will listen for voiced commands?
Oh, and where’s my flying car?
That’s more or less what the “USE_*” flags already do. It would only need a script to set or unset those. There are lots of other software projects which work this way, and even an entire OS based on the concept. Gentoo makes heavy use of “use” flags, both on a per-package basis and system-wide, to let people customize things exactly how they want… but OTOH, it also takes a great deal of time and electricity to compile everything from scratch all the time.
Anyway, use the USE_ flags.
This is the D4S thread, so it may be disrespectful to post beams from another flashlight (in this case, it is the PL47)
Nichia 219B vs SST20-4000K vs XPL-Hi-“neutral-white” LEDs on a PL47:
The SST20-4000K is a bit more throwy and also a bit brighter than the Nichia 219B, when using similar battery at fully charged levels…
Thanks for the beam shots. I’m not familiar with the PL47 but is this indicative of how they would look and perform in the D4S? I’m surprised the SST-20 isn’t closer to the XPL-HI in terms of output and beam profile.
This D4S is marvelous! i have read the 52 pages of this post and now i want one with the SST-20 5000k!
I'll think i just wait a little bit for some beam shot of the SST-20 5000k emitters added recently.
Ty for the nice review Toykeeper, and too Hank as well for this nice flashlight.
Now i just need to be strong and patient.
Ordered a D4S with sst20 3000k. Already have one with sst20 4000k which i like.
But i thought i might like 3000k. I Was about to order the M43 with 3000k, but not sure i Will like it. So i ordered D4S instead to try it out, because D4S is cheaper.
I also ordered the Another M43 in sst20 4000k.
Anyone has the 3000k yet?
Hi,
Quite a lot of reading But, which led should I use in terms of brightness up to 5000k? SST or?
Brightness is the highest with the XP-L HD.
However, for best usability in all conditions, the SST-20 5000k would be your best choice.
Is it noticable difference? How many lumens? I guess SST is more focused, giving this light a little more throw?
