suddenly I have a doubt (fear???): the batteries… the Samsung 30Q are UNprotected… i have read carefully all the suggestion to prevent some danger/explosion BUT yesterday i read some (very BAD) adventure of user of UNprotected cells…
i am little worried… probably follow step by step the user guide for handle the batteries is a right way… but if i want to use PROTECT cells inside this torch? i can? or need a modify?
I doubt that protected button tops will fit. With the plastic protection pieces in the battery carrier, you’ll most likely need button tops and the extra length of the protection circuit will make them too long. I use unprotected button tops in mine and they are a tight squeeze.
dont use protected cells in this light, that much lumens need unprotected batteries, if u are scared using this light with this combination then perhaps this light isnt for you maybe? there is no danger really if u are using quality cells and know what you are doing a little bit of knowledge handling this lights is good to have, the light is designed to drain alot of power thats why high drain unprotected batteries needed, protected will not work very good in this kind of light…
Only unprotected (flat and button top) 18650 are supported in Astrolux MF-series. Battery carrier does come with reverse polarity protection (plastic insulators near pin contacts) against batteries being loaded in wrong orientation. I would advise to add extra markings to your batteries, to help you identify the (+) and (-) poles if you are worried.
As long as it has auto off, beep for continuity and a bag/pouch of some kind to carry everything in, I’m not too picky. I have a VC97+. Two of them actually.
i am still waiting for the charger for the samsung battery… very long delivery time…
in the meantime (and with delay, because i am out for vacancy) i have check the battery received from banggood… i do no see nothing of interest, all look good… BUT… there is one cell that have a little swelling (i hope this is the right word)
looked whit eye is not visible, but when i touch the battery with my hand i feel the difference… i have grabbed a photos, i hope that the protuberance is visible…
what you think? i have to contact banggood and ask for change the single cell? or it’s normal?
if the multimeter (waiting for delivery) show good parameter for the cell, i am ok?
and last, seems that the IMALENT battery can be used inside the MF-01 (apparently the battery are the SAMSUNG re-wrapped)… also (and if i read/remember well) the MF-02 accept PROTECTED battery… it’s correct?
and again, i read that i can made a light with two head: MF-01 and MF-02… it’s possible? trow and flood at the same time…
i read the review of the ASTROLUX MF-02 in this forum… it’s a very nice light and looks impressive for the throw distance (and price is very reasonable)
for what i read, the MF-02 seems to accept PROTECTED cells batteries… right?
i googled and find IMALENT 18650 are SAMSUNG 30Q rewrapped, this is a good choice i can imagine…
and now (yes, again) the question for the MF-01: looking the pictures of the MF-02 i see the battery holder is really similar to the MF-01… so… i can use IMALENT cells???
yes, i ask previously for this, but it’s sure that i can not use the protected cells? both have 15A of drain… the problem is the protection circuit of the cell?
thanks guys for all suggestion and the BIG PATIENCE…
still waiting for the charger… damn… very long time for delivery… i want to see these 12000 lumen…
Yes the Imalent MRB-186P30 do work in the MF01 like a charm. They’re actually the only protected cells I’ve found so far that do work. Not because of the rated amperes but because of their thickness. The MF01 has quite a narrow tube, so most protected cells won’t work just because they physically don’t fit into the lamp…
BTW, anyone had trouble with water proofness so far? Flooded mine today while holding it 5cm under the water… Those O-Rings seem so be quite minimal and the slightest dust or debris will allow them to flood Thankfully it was only the battery carrier getting wet and after drying everything worked again…
How much current does it take on turbo? Couldn’t find it fast in thread. I have beed trying light with Sanyo GA and Sony VTC5A and no noticable difference in beam.
This light uses a boost driver so the output should be regulated.
It will not go into Turbo once the battery voltage has dropped to a certain point.
The GA has more voltage sag under load compared to the VTC5A, so it will not have as much total Turbo run time. If you want the most total run time on Turbo, use unprotected high drain cells.
