I bought two of these (blue and tan) and I think they were my most disappointing lights of 2018. Aside from the Group Buy debacle, the beams have an annoying halo that’s quite problematic and distracting when trying to look at objects that are within range. Even though the colors and design are very slick, there is some sloppiness such as the lack of uniformity for the tritium cutouts. When I need a light like this, I find that I almost always reach for my Emisar D4S or D4 over these.
Thanks for the review. Yes, the ramping and UI are not Narsil quality but I like it anyway, mainly for it’s simplicity . It is very stream lined and feels good in the hand. I put DC Fix on mine and the beam is beautiful now. (HD version) Nice tint. BTW, there is lock out with 2 clicks and then hold. I paid $32 so I’m happy.
I bought two as well (blue and silver), and the UI has made them both shelf queens. I don’t think I have used them again since the day I recieved them. It’s such a shame because they are really beautiful lights too! For me, the inability to turn the light on at the lowest ramp setting is what made the flashlight a bust. It takes one full click (click and release) to turn the light on. And the light turns on at whatever setting you last used. Dark bedroom headed to the bathroom, BOOM 2000 lumens :person_facepalming:
I’ve been begging to get a replacement driver for it, but I can’t find a 28mm boost driver anywhere.
May I ask where you got the DC Fix? I think it’s around $18 and I’m just not sure if I want to pay that just to fix the artifacts on two flashlights. Also, what’s the HD version? I’ve heard of people using the “frost” or “sand” version for diffusion, but couldn’t seem to google HD version. Any advice is appreciated!
As far as I can tell it gets you into group sets 1-5
Modes UI: (5 groups)
5xClicks to select 5 groups ; The light flashes once and turn it off to select Group 1 ; The light flashes 5 times to select Group 5.
But why this is not in the user manual? I don’t understand them why made a nice host and ruin it with the UI and user manual that missing information. Tried the lockout and worked on mine. I will try through the mode sets and measure all levels then extend the review with that info. Thank you!
See my google tables and compare stock light lumens to measured lumens… Most of them over estimated by manufacturer at least by 10-20. A few has better numbers than factory and some correct. I have the Brinyte PT18 Oathkeeper for test now and first it was made around 1300 lumens instead of 2000. It was a used prototype so it have gone through a lot battery changes. Then I cleaned the threads and contacts and it made 2050 lumens. So if some residue and not clean contacts can cause 40 output loss I’m ok with 10-15% difference but not like the Imalent DT35 made. It was rated 8500 lumens and I got 4500 no matter what I done to it. I complained but not worth the time…
I will not use my time to complain for all lights that I get 10-15% difference. In real life you can’t see that. But 40-50% you can see it. I will try it with some other battery and clean all contacts if that make any difference with SC26 tomorrow.
