Thanks for the review. Yes, the ramping and UI are not Narsil quality but I like it anyway, mainly for it’s simplicity . It is very stream lined and feels good in the hand. I put DC Fix on mine and the beam is beautiful now. (HD version) Nice tint. BTW, there is lock out with 2 clicks and then hold. I paid $32 so I’m happy.
I bought two as well (blue and silver), and the UI has made them both shelf queens. I don’t think I have used them again since the day I recieved them. It’s such a shame because they are really beautiful lights too! For me, the inability to turn the light on at the lowest ramp setting is what made the flashlight a bust. It takes one full click (click and release) to turn the light on. And the light turns on at whatever setting you last used. Dark bedroom headed to the bathroom, BOOM 2000 lumens :person_facepalming:
I’ve been begging to get a replacement driver for it, but I can’t find a 28mm boost driver anywhere.
May I ask where you got the DC Fix? I think it’s around $18 and I’m just not sure if I want to pay that just to fix the artifacts on two flashlights. Also, what’s the HD version? I’ve heard of people using the “frost” or “sand” version for diffusion, but couldn’t seem to google HD version. Any advice is appreciated!
As far as I can tell it gets you into group sets 1-5
Modes UI: (5 groups)
5xClicks to select 5 groups ; The light flashes once and turn it off to select Group 1 ; The light flashes 5 times to select Group 5.
But why this is not in the user manual? I don’t understand them why made a nice host and ruin it with the UI and user manual that missing information. Tried the lockout and worked on mine. I will try through the mode sets and measure all levels then extend the review with that info. Thank you!
See my google tables and compare stock light lumens to measured lumens… Most of them over estimated by manufacturer at least by 10-20. A few has better numbers than factory and some correct. I have the Brinyte PT18 Oathkeeper for test now and first it was made around 1300 lumens instead of 2000. It was a used prototype so it have gone through a lot battery changes. Then I cleaned the threads and contacts and it made 2050 lumens. So if some residue and not clean contacts can cause 40 output loss I’m ok with 10-15% difference but not like the Imalent DT35 made. It was rated 8500 lumens and I got 4500 no matter what I done to it. I complained but not worth the time…
I will not use my time to complain for all lights that I get 10-15% difference. In real life you can’t see that. But 40-50% you can see it. I will try it with some other battery and clean all contacts if that make any difference with SC26 tomorrow.
Great review. Of the 5 shown, I have the Wuben, Sofirn and the Emisar D4S. While the D4S is the most powerful, it gets hot to the touch pretty fast in turbo. I like the AUX backlight feature on the D4S and the size in hand as well. Another I would recommend in this category would be the Thrunite TC20. Thanks for your review/comparison. Saves me the time and money on this one. Very well done!
Thank you very much!
I have been in contact with a local flashlight store and I will be able to lend any of their products for testing.
They want to sell Thrunite soon so I can try them too.
Recently I got a Haikelite SC26 when it was on sale at the new Aliexpress Haikelite store. I opened it just like you and saw the R100 sense resistor there. Considering your measured tailcap draw the led should see around 1.5A. It does not get hot fast, so I thought maybe I could boost the current by adding a resistor. Do you think a second R100 would be too much?
I haven’t tried modding it so I don’t know if the driver keep up. If I mod it I will change the whole driver and put in a 3V emitter. Maybe a 3V XHP50.2
