Copper S2+ limited edition
can you swapp heads with a alu s2+ ?
I could swap the Cu body with an alu body, so I assume you can swap heads with an alu S2+.
That is a wish, right? The 18350 tube is not available (yet), is it?
With shorty tube I would consider this Cu version :blush:
Why don’t y’all send Simon a note and ask him to have the Copper 18350 tube made, if he hasn’t already chosen to do so he might re-consider it… :wink:
I asked once, he said no plans for 18350 tube since it is not high demand for such thing,
Hum…maybe we can try again? :wink:
If the members that already have a Cu S2+ (and want or…need :smiling_imp: a shorty tube) & the ones that don’t have one, are interested in shorty tubes, maybe we can check with Simon again if he’ll manage to do them!
:innocent:
It would be neat to have male/male joining sleeves (the sleeve would be female on each end) in copper to connect multiple 18350 tubes together for use with, say, a 6V emitter such as the 50.2 or 70.2 or MT-G2, even 3 tubes for a 9V MT-G2. A fourth tube for a 50.2 quad in 2S2P for 12V operation from 4 cells… the options are very broad. :wink: The sleeves would act as grip along the length of the tube. :smiley:
short tube needs a good saw, some sanding plane then solder with very little paste both pieces together
if the coating does not get damaged the result may look good enough or need some sort of mild sand blasting or so to hide the solder connection
Lexel taking a jewelers approach to resizing
i can produce some ,but i want to remove the knurning or change the style .
Product yield rate can be improved greatly if i dont process knurning
similar to sleeve of L4 flashlight ,right?
I’m new here, and new to ordering things on Ali; it says this is out of stock. Is this because he has a limited number he isn’t posting stock? I’d love this with the metal switch, is that a possible order modification in order notes?
Also, I’m hoping to eventually start modifying flashlights. Should I only order the host or is it as easy to order the full flashlight and then take the other stuff out when I’m ready to get into modifications? I’m leaning that way but would like to do things as simply as possible to get started.
Thank you for your time.
Hi and welcome to BLF Vortexbig :partying_face:
First warning, prepare your pockets :money_mouth_face:
Yup, the Convoy S2+ Copper seems to be out of stock right now. Maybe it will be re-added later! Or you can send a message on AliExpress to the seller (Simon Mao) and ask him about the availability!
About the metal switch in that light, please note that it is only available with the rubber button.
This version’s host is a “normal” one, not like the “Desert Tan” or the “Silver” with black metal button.
To put the metal switch in the “normal” hosts…it is possible (see here or here ), but the tailcap structure has to be modded. It can be done, but…I still don’t know how :smiley:
About modding, I’ll only speak for my experience: I bought the “full” light and then started by replacing the LEDs, then the drivers. I guess many people here may have started other way, so I hope they can share!!
I think the only real difference is you miss out on using a retaining ring on the driver pill. I hate soldering drivers to pills and will choose a retaining ring whenever possible. Stock S2+ lights come with the driver soldered to pill and no ring.
I believe they’re only soldered if you choose greater than 4x7135 chips. 4 or less and it should ship with a retaining ring used.
Thanks :slight_smile:
I think it’s already too late!
I messaged Simon and he responded!“Yes, I will launch next batch after Chinese spring festival. And the style will be changed.”
Chinese Spring Festival is Feb. 5th
I can wait until then :slight_smile:
you think something like a Cu Heatsink Pill could be in a Cu S2+ ?.
too much weight?.
or best just to use normal black s2+?.
If the copper S2+ comes with a 18350 tube, I’m finally in for one. Curious about the new styling :slight_smile:
Hell yes please! The only reason I didn’t get your copper S2+ is because of the knurling. I don’t really like how it looks, actually I don’t like it on any light to be honest, just doesn’t look good. If it’s just plain, I’d probably get a couple!
subscribed
