As long as it has auto off, beep for continuity and a bag/pouch of some kind to carry everything in, I’m not too picky. I have a VC97+. Two of them actually.
i am still waiting for the charger for the samsung battery… very long delivery time…
in the meantime (and with delay, because i am out for vacancy) i have check the battery received from banggood… i do no see nothing of interest, all look good… BUT… there is one cell that have a little swelling (i hope this is the right word)
looked whit eye is not visible, but when i touch the battery with my hand i feel the difference… i have grabbed a photos, i hope that the protuberance is visible…
what you think? i have to contact banggood and ask for change the single cell? or it’s normal?
if the multimeter (waiting for delivery) show good parameter for the cell, i am ok?
and last, seems that the IMALENT battery can be used inside the MF-01 (apparently the battery are the SAMSUNG re-wrapped)… also (and if i read/remember well) the MF-02 accept PROTECTED battery… it’s correct?
and again, i read that i can made a light with two head: MF-01 and MF-02… it’s possible? trow and flood at the same time…
i read the review of the ASTROLUX MF-02 in this forum… it’s a very nice light and looks impressive for the throw distance (and price is very reasonable)
for what i read, the MF-02 seems to accept PROTECTED cells batteries… right?
i googled and find IMALENT 18650 are SAMSUNG 30Q rewrapped, this is a good choice i can imagine…
and now (yes, again) the question for the MF-01: looking the pictures of the MF-02 i see the battery holder is really similar to the MF-01… so… i can use IMALENT cells???
yes, i ask previously for this, but it’s sure that i can not use the protected cells? both have 15A of drain… the problem is the protection circuit of the cell?
thanks guys for all suggestion and the BIG PATIENCE…
still waiting for the charger… damn… very long time for delivery… i want to see these 12000 lumen…
Yes the Imalent MRB-186P30 do work in the MF01 like a charm. They’re actually the only protected cells I’ve found so far that do work. Not because of the rated amperes but because of their thickness. The MF01 has quite a narrow tube, so most protected cells won’t work just because they physically don’t fit into the lamp…
BTW, anyone had trouble with water proofness so far? Flooded mine today while holding it 5cm under the water… Those O-Rings seem so be quite minimal and the slightest dust or debris will allow them to flood Thankfully it was only the battery carrier getting wet and after drying everything worked again…
How much current does it take on turbo? Couldn’t find it fast in thread. I have beed trying light with Sanyo GA and Sony VTC5A and no noticable difference in beam.
This light uses a boost driver so the output should be regulated.
It will not go into Turbo once the battery voltage has dropped to a certain point.
The GA has more voltage sag under load compared to the VTC5A, so it will not have as much total Turbo run time. If you want the most total run time on Turbo, use unprotected high drain cells.
I know, I test many cells, 8 per cell, than it is 16A all current on turbo?
VTC5A are one one of strongest 18650, but GA have more capacity when on lower modes.
If I use 2 batteries 2s1p it will still take 16A as it is overall current drain I assume? You make it less clear with this explanation. I asked if overall current drain is 16A? It is clear, that if you say 8A/cell than it should be 16A/2p.
I don’t know the specific design of this boost driver. Plus it went through at least one revision. Maukka tested an early version of it using 4 x 30Q fully charged and it drew 16A. He had to use a special test rig to get this measurement. This is why you don’t see anyone else measure it. I don’t even think anyone has tested the newer driver design. So I don’t have much info to go by.
Depending on how the Boost driver is designed, the amperage may go up as the voltage drops. So it could possibly draw 18A to 20A as the batteries drain (which would be 10A each battery).
I really don’t know what the amperage would be using 2 batteries only. It depends on the type of battery and it’s state of charge. I will just say that each cell will draw at least 16A, assuming it turns on Turbo at all.
It is best to always use 4 cells in this light.
Use high drain for more total run time on Turbo.
Use high capacity for more run time at medium to low levels.
8A is a little bit too much for GA, but on the other side, it will go down before they get hot. I am not going to use 2 cells, only wanted to determine total current to know which cells are ok for this light. Maybe when I have some time I will check current on lipo or power supply. Anyone has idea of highest voltage driver can use?
