Maybe not, there are the 3 screws holding the board tight against the emitter shelf, so as long as the MCPCB fits properly into the head then the screws can snug it down for good contact. Thermal paste would certainly help, but the copper is thick and rather large so maybe it’s not so horribly bad.
There is some sort of very thin almost oily residue on the emitter shelf in mine, and a grey substance around the edges… almost like some thermal compound had been applied but wiped off. The copper board shows quite clearly that nothing contacted it on the vast majority of it’s surface, but some of that grey is around the very edges… don’t know what happened to this particular light but it would appear it was disassembled and reassembled improperly. That would be my guess anyway.
Would the driver maybe be glued in with thermal adhesive?
Just ordered mine btw. I want to do the emitter swap that DB Custom did. It looks awesome. Not green at all. Awesome output. Hope it wont explode or catch fire.
P.S.: Why does it even work? I heard that due to the high forward voltage the LH would not be able to hold output for long. And I don’t even know what the forward voltage exactly is anf how everything plays together. Source1Source2 (especially confused about this and the Amps each light would draw and the output produced).
rennet, I’m not saying the template was rotated, I’m saying the template was laid out wrong and not indexed. One of the three holes is not in the correct position.
Kanton, I’ve used 50 LH351D emitters, haven’t had a problem with the Vf in any of the lights I’ve installed them in. Yes, FIFTY! Well, Fifty-Seven now.
If you want the Vapcell 40T, why don’t you PM Vapcell_Dennis on BLF and he will steer you in the right direction. I have this cell and it measures 4,038mah and output on the E07 is just slightly less than the 30T. Excellent cell.
They really do, don’t they? I love how the LH351D emitters look, and they make a great beam in a lot of lights. The output is impressively even and consistent.
Thanks for mentioning that… so far the D4 with XPL-Hi V2-5D is the only light I have with “5D” tint. I thought it didn’t look nice (greenish-yellow, as you mentioned), so I didn’t try gettting that kind of tint anymore…)
I have an Astrolux S1 with XPL-HD “5A” tint and that light looks rosy…
It’s sort of off-topic here, but maybe someone can send me how a 5D tint is supposed to look like?
At first batch of ROT66, we used many paste under MCPCB, but still has some emitter-burnt issue. We inquired the paste suppier about it.
Then we got an answer from their technicians.
1. For thermal conductive rate: Flat surface metal > Paste >unflat surface metal. In reality metal surface are not 100% flat, so we need add thermal paste on the metal surface. They guide us that If the metal surface is flat enough, we should add a thin layer of paste on the metal surface to ensure the best thermal conductive.
2. The bottom of the MCPCB is very flat , The aluminum shelf is not 100% flat, So we added a thin layer of paste on the E07 head. We have done a lot of thermal test , no one led burnt at max turbo.
*For E07 SST20 / Nichia version , we only recommend max 20A battery , 20A battery can reach max power for E07 SST20/Nichia version. With a 30T battery on SST20 or Nichia the turbo will go blue no matter how much paste used.
Yes, and DB Custom knows all this. He makes some of the brightest and hottest lights in the world.
However, what he found was not metal to metal contact. It was not metal to paste to metal. It was aluminum to paste to air to copper. This is even worse than having too much paste. There was an air gap between the copper piece and the aluminum, and it is important to make sure that gap is filled with paste instead of air.
It is true that the paste should be as thin as possible… but it should not be so thin that it leaves an air gap.
I seem to have an underperforming light . I bought 2 . One is an XLP 6500k . The other is an SST20 5000k. The XPL will hit 6800 lms at turn on . ( TA meter ) The SST will only reach around 1500 at turn on with fresh charged 40T . I have cleaned all connections , tried different batteries , It drops very quickly 2 seconds after turn on . Down to like 500 lms.
I have not checked thermal configuration . After seeing DB’s post of no thermal paste , I am not sure what the safe , maximum temp I can set it at . Also , does this seem like it may be the the cause of this lights problems ? ( thermal config )
I so want one of these, on the other hand, I so don’t! Maybe in 6 months time…… nearly all the feedback on Fireflies lights seems to be 50/50 on quality/problems etc. Still this can only mean better things to come.
