strange... new-style WF-504B body and bad heatsinking. I got two along with 2 fake solarforce L2's and a few other (the commonly called skyray) and it seems it does the job somehow equally good. It does look worse for heatsinking i would agree but the body temperature with foil is on par with fake solarfarces. Upon disassembling the heated dropin's there was no way to tell which one was warmer. Maybe you got a old style 504B that is way better than all my p60 hosts combined. One wonders...
Not trying to defend manafont but i got the body purely based on aeasthetcs because it is more appealing to L2 and clones to me. Have not found a flaw yet. Perhaps antiroll capability...
Ceiling beamshot in new style 504B. The XM-L is on the left, the right hand one is a low voltage Solarforce single mode R2 dropin in an L2i with an 18650. Yes, the hotspots are burned out - this is just a quick shot before I take the dog out.
The odd shape of the XM-L beam is due to the bezel ring on the 504B.
Throw at 1 metre is 5250 - you can see from the beamshot how huge the hotspot is.
5250?! Is that the same measurement that gave 3240 on the MC-E M bin? (edit: no, I was getting throw mixed up with lux). Of course, it's a given that they sent you the best one they had and all subsequent ones are going to be garbage. Sounds really great so far though. Do you have a current draw on it? LED is secured well?
I had to go and get the dog a new eating bowl. The city is gridlocked, but I'll do some testing once I've eaten - it has taken me more than 2 hours to get back from the dog dish shop about 3 miles away.
Problem is the rural hinterland shoppers who infest the city at this time of year. They tend to drive extremely slowly in the middle of whatever road they are holding up and tend to be erxtremely aggressive drivers as well.
Add to this a blizzard and the rush-hour and the conditions get really bad.
And my assistant threw up all over the back seat of my mother's new car. The new dropin will certainly get some testing while I clean the seat.
Couldn't face cleaning the seat just yet. I'd made a mistake with the throw numbers - it was on medium, not high. The throw number I'm still finding hard to believe.
Lightbox
Light
Battery
Immediate
KD XM-L Dropin High in L2m flat bezel
18650
3160
KD XM-L Dropin Mediumin L2m flat bezel
18650
1250
KD XM-L Dropin Low in L2m flat bezel
18650
125
Same meter, same conditions as the MC-E. I'd better go and see to the car seat before I play any more..
Not bad spacing though medium might be better a little lower.
The head does get warm - there is a lot of aluminium foil stuffed in with it to make it a tight fit.
But the lumen maintenance over two minutes is extremely impressive - this may be the best maintenance of light on max of anything I have. The reflector seems a bit different from the usual P60 one. I'll do some pictures to explain, I've failed to put it into words.
The LED is not perfectly centred in the reflector as you can see from the picture above.
There are certainly more XM-L lights in my future - I never bought a huge number of XP-G lights - but I can see me replacing most XR-E ones with XM-L's or modding the XR-E lights.
If it'll stop snowing for a while I'll try for some beamshots, I've dug out an M bin MC-E, my brightest P7, an R5 and the XM-L. All have fresh from the charger 18650s in them.
Since the test range is a lot more reflective than usual, I'm going to drop the exposure a lot so the next shots will not be comparable to the usual ones.
You have to take off about 30% from LED figures to what a light puts out the front. This is why I almost always use the L2m body and flat bezel ring so at lest the losses are consistent.
The XM-L does need a lot of current from what I've read - at lower currents an XP-G can beat it from one test I read somewhere.
It isn't close to the claimed output but which one ever was?
The LED certainly isn't getting 3A, probably in the 2200-2500mA range. It might actually be brighter than the MC-E - it certainly is after a minute - remember the errors in these tests could be quite large.
