Wow...
Wow...
I had to go and get the dog a new eating bowl. The city is gridlocked, but I'll do some testing once I've eaten - it has taken me more than 2 hours to get back from the dog dish shop about 3 miles away.
Problem is the rural hinterland shoppers who infest the city at this time of year. They tend to drive extremely slowly in the middle of whatever road they are holding up and tend to be erxtremely aggressive drivers as well.
Add to this a blizzard and the rush-hour and the conditions get really bad.
And my assistant threw up all over the back seat of my mother's new car. The new dropin will certainly get some testing while I clean the seat.
You've been on a real lucky streak lately with cars and weather . . .
Also, like to know how well the modes are spaced and if the light has memory. You know, while you're in the car, cleaning up.
Couldn't face cleaning the seat just yet. I'd made a mistake with the throw numbers - it was on medium, not high. The throw number I'm still finding hard to believe.
Lightbox | ||
Light | Battery | Immediate |
KD XM-L Dropin High in L2m flat bezel | 18650 | 3160 |
KD XM-L Dropin Medium in L2m flat bezel | 18650 | 1250 |
KD XM-L Dropin Low in L2m flat bezel | 18650 | 125 |
Same meter, same conditions as the MC-E. I'd better go and see to the car seat before I play any more..
But first I put the details into the Google Docs spreadsheet
Oh my god! 567 lumens on med mode!
How about the heat on MAX after 2 minutes Don???
Imprehesive!!!!!!
Can you measure current draw on HIGH and MED, when time permits? thanks!
That looks really really nice! : ) Now I have to get one, lol!
2600mA High
960mA Medium
90mA low
1100mA strobe
Looking good!
Definitely an XM-L, not something one can take for granted from HK dealers.
But...... 567 lumens maximun? maybe is not driven at full specs? or bad dissipation?
Umm draws 2600mA on MAX.... lets imagine the LED gets 2400mA...........
ummm
About 1A on med mode and only 220 lumens? an xpg-r5 at 1Amp gives 320 lumens
Mode spacing is roughly 100%
40%
and 4%
Not bad spacing though medium might be better a little lower.
The head does get warm - there is a lot of aluminium foil stuffed in with it to make it a tight fit.
But the lumen maintenance over two minutes is extremely impressive - this may be the best maintenance of light on max of anything I have. The reflector seems a bit different from the usual P60 one. I'll do some pictures to explain, I've failed to put it into words.
The LED is not perfectly centred in the reflector as you can see from the picture above.
There are certainly more XM-L lights in my future - I never bought a huge number of XP-G lights - but I can see me replacing most XR-E ones with XM-L's or modding the XR-E lights.
If it'll stop snowing for a while I'll try for some beamshots, I've dug out an M bin MC-E, my brightest P7, an R5 and the XM-L. All have fresh from the charger 18650s in them.
Since the test range is a lot more reflective than usual, I'm going to drop the exposure a lot so the next shots will not be comparable to the usual ones.
You have to take off about 30% from LED figures to what a light puts out the front. This is why I almost always use the L2m body and flat bezel ring so at lest the losses are consistent.
The XM-L does need a lot of current from what I've read - at lower currents an XP-G can beat it from one test I read somewhere.
It isn't close to the claimed output but which one ever was?
The LED certainly isn't getting 3A, probably in the 2200-2500mA range. It might actually be brighter than the MC-E - it certainly is after a minute - remember the errors in these tests could be quite large.
So visually the XML is brighter than your MCE, no matter what the numbers say
Yes - it is also a better colour and no holes in the beam at any range.
Beamshots uploading now. Turned out the R5 I'd grabbed was actually a single-mode R4 so it got left out.
While I wait for the beamshots to upload, here are Lambda's from his Varapower lights with an XM-L in them.
http://flashlightnews.net/forum/index.php?topic=2398.msg30577
Control. It isn't all that dark as the cloud level is about 100m and there is a lot of reflected light pollution.
XM-L High
XM-L Medium
XM-L Low
MC-E High
MC-E Medium
MC-E Low
P7 High
P7 Medium
P7 Low
Great stuff Don!
Now I am excited to get mine!
Those beamshots pretty much put the last nail in the coffin for the P7/MC-E for me...
Thanks for the photos.
-Match
I did never buy a MC-E or P7 and it looks like I don't need one in future. I ordered The XM-L C8 from KD and I hope that one will even perform better than these drop-ins.
