Lumintop GT4
Yep, that^.
Wow that’s a beast! Any info on the driver? Buck or DD/FET?
Well, maybe. But the Boost HX is a ~3v chip, so I don’t think the slightly higher current going to the buck driver will be enough to cause problems. Obviously, I could be wrong. :stuck_out_tongue:
Also changing from 18650 to 21700 already requires “new hardware and more development costs” so the difference 2S or 4S isn’t significant in that regard.
It’s not going to use a buck driver though.
A 250W-300W flashlight sized buck driver would be extremely expensive, where a FET+linear regulator design would still work adequately with 4X XHP70.2s.
And besides, the 1mm2 Olson HX Boost only comes in 6000k+ variants, which look way too blue.
Lumintop could easily offer a CW XHP 70.2, and a NW 4000k XHP70.2 model, which would easily satisfy almost all customers.
It will be using a beefed up version of the GT70 driver basically, so 2 channel FET driver.
A buck driver would be nice but a ~40A buck driver is no simple task and it would be very large, I know this from experience on a light that never went public.
The boost HX is an interesting idea for a future version of the light but it will not be something done at first that is for sure seeing as they are not even out yet.
Can it run on 8 AA?
lol, not exactly.
Ohhhh shoot…lol…cant wait for it….
Is the head the same size as the BLF GT? Is the heat sink the whole head? Looks to be one piece, any info on that? Any side pictures to see how deep are all the fins?
Yes, same basic size as the GT / GT70.
Yes, all those fins on the head are used for heat sinking pretty much.
Here is one of the earlier CAD designs, I can’t find the latest one at the moment but it as only minor changes.
The cooling on this light should be quite good to say the least.
Thanks TA! :beer:
No idea, looks great though! Just saw it on FB this evening. Hopefully should out-do the old Shockers - think the best I got was over 500 kcd. Some slice&dice action on those biggies should do.
4 xhp70.2s in huge reflectors vs 9 xhp35 HIs in smaller reflector wells would be an interesting comparison. seems like the gt4 will make for slightly more lumen but slightly less throw.
Well, for one, it will have better QC, replaceable cells, non exaggerated specs, NarsilM.
And where did you find an R90C for 200$US?
The lowest price I’ve found with a coupon is 280$US.
It will be more reliable than the R90C specially at the driver, step down is user-controlled, probably brighter, much better heatsinking, and most likely without the fogging issues of immalent lights.
Sadly max output will drop accordingly to the battery level, being a direct drive setup.
And can be used with 8 18650s for much better runtime.
And you can get the light in Neutral White rather than Cool White.
This light was first planned WAY back when the GT was still in the planning stages. Needless to say things have progressed since then and it is not quite as revolutionary now as it would of been 2 years ago.
At this point, yeah there are other lights that would be direct competition for sure. How they would compare is something I can’t know without some testing though.
Lumintop finally said they want to proceed with this project and I was sure not going to say no lol.
Based on VOB’s lumen readings from the R90C though, I do expect higher lumen output from the GT4. My goal is ~20k real lumens or more.
Imagine 4 CFT90 in this thing. Power draw and cost would be unrealistically high.
4 2mm white flats would be nice as well.
Sure.I’ve got it at $290.00 .
