how is the beam in the 2mm^2 version? I see the die is rectangular, I wanted to use it in a C8 host but I don’t know if the beam is going to be right or this led should be used only with aspherical lens
the sofirn c8t driver can be bought from sofirn store on ali. its max 4.5 amp according to them.
Is there a reason this wouldnt work?
its pwm tho so regulated should be better right?
Osram on left, stock on right.
In real stock is more warm than on the picture and Osram is less blue.
T:2s ISO 200 F: 4
I didn’t measured throw.
Yesterday was foggy.
From 5m osram has a hole inside the beam.
I guess the correct distance to measure is around 25 m.
You are right! :+1:
I measured osram led lights and GT xhp35HI version at 15, 20, 25m
If you have a hole in the beam at 5, 10m in MF04 with osram you are close to good focus. From the image I think it is perfectly dialed in.
The distance in which the hole dissappears depends on the relation of the diameter of the reflector to the size of the LED. The bigger it is, the longer the distance.
I documented my experiences regarding this topic here and did some simulations here and here (in German).
All focused lights should have a hole in their beam at close range. Even small edc type lights will have a donut-hole hotspot in the first couple of inches of their beam. Super throwers will have this hole for many meters.
I wish someone would make a new thread solely about focusing thrower LEDs with steps, tips and best practices. It’s one of those things people talk about but never in detail. When I made a thread about how crappy my spring bypasses were everyone chimed in and I think it was very helpful basic topic (to me) to rehash after so long.
This is around 30cm from the wall with convoy c8 and 7mm gasket from int outdoor.
This is around 1 meter from wall with c8. I didnt sand anything down just aiming at the ceiling unscrew the reflector a bit and tightening it again till best centering is found. At 3.05 amp this led is already insane in a c8.
Thanks, exactly what I was hoping for. I replied with a few questions. On paper this seems like a much more practical solution than eyeballing or messing with a lux meter at too close range.
