The Vapcell 5000 I have is 15A marked, and has the annoying great depression on the batt+ end -- pain to charge because even a magnet won't stay in place.
Yea Lux, think you are right. I was hoping the Shockli's, Sofirn's anf LK's were true rewrapped 40T's, but clearly not now. Notice how tight they all test in amps? Chances are good they are the same cell, I'd say.
Huh? I'm not familiar with the problem that needs fix'n, and probably won't be doing any more battery testing. I haven't taken my E07 apart yet.
Ohh, u mean the lack of thermal grease? I don't know, is that really true? I'm very confused reading the posts and seeing pics - whether surfaces were cleaned or not. Maybe I missed something? I see pics but not a clear explanation, or some posts but no pics.
My tests above were just at turn on, mainly because of the low temp setting for thermal regulation. Tried resetting it but I guess for 30 sec tests with raising the thermal reg, better take her apart and check the MCPCB...
I don't like posts that keep you guessing - say it or don't mention it - Martin's post with the pic is not clear to me. The pics with clean MCPCB's and clean shelf top is exactly what I would do - clean the surfaces, re-apply good grease before re-assembling. There's nothing odd in those pics.
If this is true that they are not using a single drop of thermal grease (??), then that's a pretty bad oversight for such a powerfully driven light. I expect to see this in 1-2 amp cheap budget no name lights (like TESLACOM ), but not a light like this. If they are doing this in an attempt to keep the housing cool, or not heat up super fast, that's even worse.
Tom E, the problem is there is a thin air gap between the MCPCB and the shelf. So the stock thermal compound doesn’t come into contact with the MCPCB.
I fixed mine by making sure my MCPCB is flat (ran it over fine sand paper on a flat surface) and also ran it over the sand paper at a 45 degree angle over all the edges so it sits down into the shelf better (the edges of the shelf are a little rounded).
I don’t think their intentions were bad. From what I understand the MCPCB is just slightly too large to sit flush with the shelf. The super thin layer would have been fine if it was flush since it’s screwed down. I will take mine apart soon to verify but I suspect I have the same problem since mine has a “delay” in the body heating up.
Yeah, well … Tom I said with the pics that this was taken immediately upon seeing the situation, clearly show it right beside the head of the light and actually say the hemostats used to pull it out are still holding it. It’s true. No cleaning supplies were harmed during the filming of this picture.
Not only that, but the MCPCB doesn’t fit onto the shelf, it’s held away by the corners and needs a little work to sit down onto the thermal paste you put on it when you do this. If you don’t file it down some, you’ll be wasting your time as there will still be air pockets between the MCPCB and shelf.
So distrustful, what’s a guy gotta do?
There is some paste on the shelf, it just doesn’t touch the MCPCB due to the non-fitment issue. Even at that, it’s a very thin wiped on layer of grey paste that ends up only touching the very corners of the bottom of the MCPCB.
One sure way for you to find out, but you’ll see what I and others show in their pics should you go there…
Sorry, no idea what pics or posts you are talking bout - must have missed it. The only one I saw was the one I linked above. Too many posts, not enough search time....
I had no idea what this post was about, was staring at it for a while - no clue what I was looking at or what is was about -- now it makes sense. I totally missed, I guess, posts about this flatness issue. Too much on finish, colors, clips - you know, the important stuff
Ahh, ok Thanks! I'm starting to get it now. Sorry, takes me a while...
All this stuff is so much more critical on high powered lights. I've seen this many times before so when I have a light apart, I just make it a habit of checking the MCPCB and shelf flatness. For an MCPCB, sanding the bottom on a flat surface is the ultimate test - it can tell you a lot about the surface. For the shelf, sometimes you can see the problems, sometimes it helps getting a straight edge on it, and get one as close to the width of the shelf as possible. P60 pill surfaces are notorious for being unlevel, but can be leveled with a flat ended punch easy enough - few taps.
Seems like FF is a newbie at all this. Always check your vendors for quality, insist on them meeting detailed specs and do their own quality checks to ensure all spec'd dims are met or exceeded, penalize them if not done so. Might be difficult with typical sourcing over there though.
After you pull the star out, run a handfile around the edges to chamfer the lower edge of the star. Keep the file perpendicular to the star so there is no chance of it slipping and hitting the LEDs. Should take no more than 10 minutes with a small file to make a 1mm chamfer all around the lower edge. A quick few swipes with a file over the bottom the star with a file should be enough to get any burs at the bottom of the holes.
Course, it might be harder if you plan to run a razor blade over the bottom like a previous poster did. Safest way to protect the LEDs if you plan to do that is to remove them all, fix the star, then reflow them all afterwards. I think that’s overkill though.
My E07 heats up pretty quickly. Probably no thermal paste like Martins. I mean I don’t care if you’re an amateur building your first P60 pill, this is basic stuff. I have 4 ROT66 with no issues, 1 PL47 with broken AUX LEDs, and now this E07. I’m not even looking at his stuff any longer; I give him credit for customer service I will say that much but at some point you have to do your job better, not worse.
7 low voltage LED's, heavy teflon coated short LED wires, decent FET, decent springs, the LED+ wire goes directly thru the driver spring, combined with a decent 21700 cell -- this light pulls more amps than the way bigger Q8, so it will warm up fast even with the poor contact the MCPCB has.
I just got mine fully apart, except for removal of the switch. I used 600 GRIT paper and sanded smooth the MCPCB, then got it mirror smooth with 2000 GRIT, so sanding on a flat surface, I'm pretty confident it's flat now. I used an Exacto knife to trim the big wire hole edge - don't want sharp edges there to fray wire coverings. The switch wires are long enough to tilt the driver out, but not long enough to clip/re-program the MCU - sooo close though. Might fit with flexible silicone coated LED wires, not sure. The driver was mounted with the glue that's like rubberbands - flexible, stretchy. I poked it out with a solder pick tool through the wire hole - broke the bond fairly easy, no damage but I was careful, no hammering needed. I don't see any problem with the width of the MCPCB in mine.
Considering how super thick the MCPCB shelf is, the head is pretty light weight. It's nice to see a light built this way, specifically designed for low profile TIR optics but the style is more conventional with the elongated head so it can be packed with aluminum, all in one piece with the outer shell - I think that aspect is quite unique, and for us, really nice! They probably could have reduced the length by 5+ mm or so and still had a decent thick shelf. I think the Emisar's went overboard with priority given to as min length as possible. Their pill space is super tight and not much metal in the heads, while the E07 least has some limited space in there, plus lots of metal. It's all a tradeoff of course.
I like military watches (doesn’t everybody?). Everybody and his dog makes a model but what very few do is to raise the bezel just enough to avoid contacting the glass. Just a few millimeters.
If I was designing it, I would explore how much I could raise the body or sink the switch to make it less liable to self turn on if it hit something. Not much, just a few millimeters. Maybe 5. Of course there is no guarantee that it will never happen, it just reduces the probability by a a substantial margin. Plus the rubber on the switch is probably the second most vulnerable thing.
There's been lots of discussions on the switch height and protection on just about every light with a side switch here. Not sure, but thought ThorFire did set it a bit lower, but of course, not low enough. There were issues like this we just couldn't get them to budge on for various reasons, so we eventually settle, like we did with the screws securing down the driver - really wanted a retaining ring. Also wanted a better FET, didn't get that either. It's all about what they can do or can't, pricing, priorities, adding further delays, etc.
I’m not sure why they would resist. It’s a matter of machining and that is about the easiest thing to change. Literally ZERO cost. They have to mill a hole, they can very easily mill a countersink. Just programming.
Perhaps I can help on the next build with machining and manufacturing knowledge.
I can't recall, others might know better. Not sure if we gave it priority, and might have been a slippage issue - when you are running say 6 months behind, and they tell you it would delay another month of this or that, you tend to back off. Of course it doesn't really happen till another 10 months, but of course we didn't know that at the time -- hindsight thing...
If it was a specific resistance to countersinking it then it had to be the switch itself. Either they had stock, wanted to maintain commonality to their other products or simple unavailability. As is, the switch may not be thin enough or the threading wouldn’t close to hold the switch if there was 5mm less of material thickness.
On the other hand, they could accommodate that if they wouldn’t remove off as much from the top, where the fins are.
I’m looking at the Thorfire Q8 and they could of left the ridge/fins on there and countersunk the switch. As it is now, it’s about 3 mm proud of the machined plane. It looks good, but I always chose function over sexy. On the other hand, I’m not selling flashlights.
