Sorta depends on what you want out of your light. I modified a Sipik SK58 with an XM-L and 2.8 amp driver. Added a reflector for extra flood and filed the body down so the head would retract closer to the emitter for a much wider flood.
The result? A beautiful, very bright and very wide flood mode with no rings or artifacts. Puts out a lot of light. More than my Sunwayman V10r on AW IMR 16340. Nearly as much as my Zebralight SC600.
In zoom mode, the light gets a lot less beautiful. Every tiny scratch and ding in the plastic reflector I used becomes visible as the aspheric lense focuses on it. Result is a perfect image of the XM-L die surrounded by a wide ugly halo. Fortunately, this ugliness is only noticeable in a white-wall test. If I'm actually outdoors and shine it on something in the distance, the beam looks fine.
However... even though this focused beam is ugly, and even though I lose half the lumens inside the bezel in this mode - it still provides enough throw to see quite a distance. Much further than my SC600. I recall reading about someone who did a similar mode and measured the throw at around 12k lux. Sure it's not the 19k lux that my Q3 emitter EDI-T T11 zoomie gives, but it makes up for it with a much better, brighter and artifact free flood.
Bottom line: An XM-L zoomie's throw is pretty bad compared to a small die high surface brightness emitter like an XRE or XPC. However, if what you want out of your light is something with great flood for close in work that just "happens" to have the ability to switch modes to give some mediocre throw, then an XM-L zoomie may be just the thing.
"what are you talking about, this just came out" and then referred me to some about DX page
I replied w/ the line from the listing that says usually 4-7 days or whatever, and said it does not say in stock, and that if one ships before the end of the month I'll eat my shorts
34% more brightness is crap if the flood to throw setup eats up most of your lumens anyways, especially in throw mode. Yes the flood mode is nice, but Im perfectly happy with my XR-E in flood mode too.
If you are going to bother with an XM-L F2T, you'd at least want one driven at 2+ amps which will be a significant upgrade from your P4 or XR-E one, (in flood mode anyways)
Whoa! DX didn't have it on stock, but still delivered in less than one month!
Ordered 3/19, Shipped 3/25, Received 4/12. Not bad at all.
And the light is very good for the price (which has gone up to $15.99). I'll write a full review soon, but here are my first impressions:
Pros:
- Small, but feels good / secure in hand because of the tail design
- Bright enough (~2.0A on high, 0.9A med, 0.3A low)
- Nice pill design (large enough, screw-in, screw-in internal ring to tighten foil & emitter)
- Good thermal transfer (whole light gets hot quickly)
- Rotate to zoom (good in my opinion, or at least different)
- Nice & even flood
- Build quality is OK
- Orange bezel looks cool (or at least different)
Cons:
- Small connector in the tail cap turns the light into twisty with some cells (shorts negative end of cell to the body)
- Quite big hotspot when zoomed in (2xYezl T9)
- Foil around emitter was not centered (easy to fix)
- Strange SOS (very fast)
- Ugly ring around the zoomed in hotspot
34% more brightness isn't true . 34% more lumens....but brightness is somewhat deceptive since you can only see 25% of the 34% you're talking about ... factoring in the inverse square law of perceived brightness ....So you can say 8% perceived brightness . since it's a cheap light you can also possibly assume the aspheric is wrong for the xml and like you said the bezel is blocking light , theoretically there could be an overall loss of brightness and severe loss of user friendliness with a no throw "flood to no" light .
but I modded my z6 xm-l zoomie - copper heatsink, glass lens, xm-l U2 at 3.5A (had one more chip for nearly 3.8 but that seemed a waste), KD V2 so I have super low and med that will run a battery dead w/o overheating.
percentages, meh...
all I know is, (inside 150 meters) it makes my XR-E zoomies look like kids toys
I ordered this one because I have the XP-R3 version of it and I like its build, plus I like its locking zoomy. This one I currently have can throw over 200m. But I hate the rings.
If it's driven hard, it will blow up soon. If it's driven mildly you'll be disappointed with the amount of light when in trow mode.
That flashlight is ok for LEDs that aren't generating much heat, like XR-E, but with XM-L the amount of heat might be the a big problem, and XM-Ls already aren't ideal for zoom lights.
In any case, good luck, let us know what you think when you get it.
First i will like to say is Thanks for this forum. Its great.
2 monts ago i have orderd 2X18650 with xml-t6 it was driven with 1.10A. The led was after 20 min dead, i think there was a failure in driver that blown the led. I bought a new driver and a new led, now its driven with 1,6A i could be more but i think my batteries are low current and they cant manage current more than 2A. I am very dissapointed with the throw function. Its not so many bright as my other zoom flashlight with P4 and Q5 led. And yes its true that the xml t6 led in that cheap housing can very fast heat up. I will to buy another zoom flashlight with 1 18650 batt. what do you suggest in the budget segment.
I'm not really bothered by the 900lm in its specs, it is overrated IMO. It'll probably be just 250-400lm max and its body mass looks enough to take the heat. I know that it will not be much good as a thrower but I just want a flooder that has a zoom function if the need arises.
I saw these two videos before and it seems good enough for me.
I also have the Tank007 TK-737 XR-E but was a bit disappointed with its flood. When I saw those videos I was convinced that a zoomy T6 would be good for me. Other than the zoom function, its flood also benefit from the aspheric lens based from the videos.
