Yes, Hank turned out so nice that one of them sold me
This is a very interesting mod Komeko. Can you comment any more on how you did it? Was it an easy driver swap?
Well, the tube is glued, so I used heavy tools. The driver was a bit too big so I polished it a bit. The diode is XP-LHI 3A. MX4 paste. Of course, I set the thermal protection to over 70 degrees Celsius. The turbo withstands 90 seconds which I consider to be a great result, after which it gently goes down. The temperature after 6 minutes is 76 degrees, hot, but it does not bother me. I have the same set of Emisara D4.
Received and modded a new Raspberry Pi 3 B+ today.
Now running libreelec 9 and it couldn’t be any better. Only 31°C while streaming 720p with a copper heatsink and no case.
Love it.
Purchased and fulfilled via Amazon because I had to empty my Entropay cards (they are shutting down, if you have money on Entropay either withdraw it to your bank account or spend it!). Delivered in less than 24 hours without Prime. wow!
I can not believe how much computing power you can get these days for a budget of 35 $US.
Sweet… Got a couple not to long ago, with projects lined up for them…
One really cool project for BLF folks would be 18650/battery discharging automation with a RPI including plotting.
Or a more complex Luxmeter or other light measurement.
What projects are you planning @LouieAtienza ?
I run PiHole on another rpie 3 that also does Flightaware (Piaware).
One project I have is for a touchscreen-controlled lightbar system; I have a 4-channel relay board and some MeanWell boost drivers that can do 0-10V dimming. So it would be cool for the user to save configurable presets for the center throw lights and outer floods, and even have each preset “morph” into an other. My other project was a small portable CNC engraver that I can take on-site for doing on-time award engraving… but not sure if I’m going to get to that one. Being I have a small benchtop router, mini-mill, and 3D printer I’m not sure I need another “mill,” though I have a small mini-lathe that might end up getting the CNC treatment.
I got a 0W just waiting for me… company finally changed from their windoze-only vpn to one that’s also available for linux, and with the 0W I can just stickytape it to the back of a monitor, power it from the monitor’s usb socket, and with a bluetoof keyboard have the entire setup, well, like that.
HDMI to the monitor, bluetoof to the keyboard/trackpad, usb for power, built-in wifi to get to the outside world. What else does it need?
Best part, I got the 0W for either 5bux or 10bux at Microstore. Forgot which. Mightta been the 0 for 5bux, 0W for 10bux. Either way, it’s a steal.
I envy y’all’s knowledge that allows you to “play” with these things. I was seeing the Pi Rasberry as a gift for ordering other things and had no clue what to do with it… oddly enough I got out of high school and started college in computer programming back in the day. lol (Cobol, keypunch, like that… 1980)
I started with the very first Raspberry Pi when it came out, didn’t know what it was but was taken aback it was designed and manufactured in the UK. Back then I lived in London and I didn’t believe something that cheap could have any value when assembled in a high-cost country.
How wrong I was! That first Pi blew me away, it was my third entry into the linux world (only used Linux on x386 and newer as a child) and what a great one it was. Even though the whole concept was initially to educate younger children, it was immediately sold out and used by everyone.
Now I run entire home networks and automation with my collection of Raspberry Pis.
I haven’t kicked off any flashlight/light projects yet, but I’ll think about a few things now.
edit
On my to-do list would be
Raspberry Pi running some form of lux meter, other light measurement
Automation for lithium battery charge/discharging (including plotting/graph online)
OBDII Pi for automotive applications
I appreciate you taking the time to respond. I have never had my H03 apart. Dont really know what’s going on inside of it yet. But this may be a mod I’d like to copy. Thanks again for sharing.
Raspberry Pis are absolute golden.
I currently have PiHole set up to block ads on certain websites on my phone mostly.
MicroCenter has it for $5, but you can only buy one per day. If you buy 2 it’s $14.99 each. The salesman told me it was to avoid people buying it in bulk and reselling.
Only thing I see with Bluetooth is probably anyone could “discover” your 0W and control it with their device… Depends on how nefarious the neighbors are.
edit: Looking again the 0W has 2 microUSB ports so you should be able to just get a USB to microUSB dongle and run a wireless USB keyboard/mouse.
RPi (even Zero or ZeroW) would be pretty good for something like that. A year or so ago I built a lumen tube using a Wemos D1 Mini (ESP8266) running Arduino and a TSL2591 breakout board. Super small, USB powered, and feeds out results over WiFi via a built-in webserver. It makes runtime/output charts really easy.
Nah, you’d have to pair the beasties first.
Yeah, I already got some Logitech critters that need the dongles, but wanted to avoid even that.
Put some 3000k sst20’s from kaidomain in my D4. Just love this emitter.
Sort of a mod… after the success of modding the light pods above, another friend asked if I could make a smaller single ATV light with a wider beam. Not wanting to dream up something from scratch, I put together two things I had laying around - some LED heatsink housings, and some 2” dia. round heatsink. Milled a recess to set the main body of the housing into the heatsink, and another recess to cut 1/2”–14 NPT threads that the housing base has. I don’t have a threadmill so I did this manually with a tap and 15” wrench. Not fun, but done. The “pill” only has a center hole for the wires, and I’m running the lights in parallel (partially because I shorted out and fried the Meanwell boost driver I had). So I had to open up the hole on the MCPCB and pill. The board is a triple XHP35.
Wanted to share some “beamshots” this is a more “floodier” light for me.
Here’s my control - back yard, some ambient street light, though still rather dark:
And with the light on:
The apartment building across the street is about 50ft. away:
Shedding some light on the subject, literally:
Couple of firsts for me today, been a while since that’s happened. Modded an Dereelight XSearcher for a buddy of mine with a White Flat. This was originally built up by Vinh with a de-domed XP-G2 and direct drive… it did some 460Kcd in that configuration. So I put a White Flat on a 16mm board (had issues with positive grounding) and built up a Qlite with Biscotti on it by stacking 7 350mA 7135’s. With a rested 30Q at 4.12V it pulls 4.82A and makes 775Kcd for 1.094 miles throw and this even on a 5M test! Wow! The White Flat is one serious little thrower, for sure!
Yay! My shipment of bare 4000K and 5000K LH351D arrived from Mountain Electronics today.
This is the first time I’ve tried this emitter. Going to have to swap them into something this weekend to see how they perform.
I like the Samsungs in the D4S and E07.
Edit: Actually my scratch built Ti/Cu Quad is where I really like the Samsungs, this is my EDC and the light I use more than any other.
