I wonder it that 18650 to 21700 Battery Adapter would work on other 21700 lights as well??
i am very sure it will ;)
/\ …. Thank you MM.
It is basically adding 5mm in length and 3mm in diameter to make an 18650 fit where a 21700 would go.
Thanks Jason, that’s what I figured; but…. I also was wondering/thinking the base might possibly be proprietary to the Astrolux models listed.
Either way, I ordered a couple. :+1:
d_t_a:Any idea for the estimated lumens of the Convoy S2+ SST20-4000K for each of the 4 variations (7135x3, x4, x6, x8; ie. 1.05A, 1.4A, 2.1A, 2.8Amps)?
If we take the example of 2.8A = 650 lumen then we can extrapolate the lower units based off the typical output curve. So probably something like this:
3x - 280lm
4x - 360lm
6x - 510lm
8x - 650lm
This values seem a bit on the high side, since Simon is using SST-20-W40H-A120-J4402 , i.e. J4 Flux Bin (3A @85ºC 556lm)
JasonWW: d_t_a:Any idea for the estimated lumens of the Convoy S2+ SST20-4000K for each of the 4 variations (7135x3, x4, x6, x8; ie. 1.05A, 1.4A, 2.1A, 2.8Amps)?
3x - 280lm
4x - 360lm
6x - 510lm
8x - 650lmThis values seem a bit on the high side, since Simon is using SST-20-W40H-A120-J4402 , i.e. J4 Flux Bin (3A @85ºC 556lm)
It’s all relative. If 2.8A = 520 (20% less than 650) then adjust everything down 20%.
3x - 225lm
4x - 290lm
6x - 410lm
8x - 520lm
Does the FT03 group buy include the 18650 -> 21700 adapter? It’s supposed to be 26650 compatible too so how can a 21mm cell adapter work?
Yeah I’m kind of worried too…
I mean, I planned to use a 26650 in it
Thanks saypat… it worked fine for me this try also. :+1:
You ordered a 4000°K flashlight ?
You’re a bit below your floor CCT’s preference if i’m not wrong. I do hope you will appreciate its colors rendition despite its yellow tint.
I use a Lee 804 filter in the one that I just received, it kills most of the green at low levels an gives a bit of a rosy tint
teacher:Thanks saypat… it worked fine for me this try also. :+1:
Shhh… you weren’t supposed to tell. …
Yeah, I did order one. :person_facepalming: And your right, it is below my usual 5000K “floor”. But the price was right & I do not have a SST20. So after reading all the talk about it, I thought I’d give it a try.
It I were to end up hating it, I’ll just gift it or change the emitter.
I figured it is a win - win situation.
@teacher,
Yes, same message repeatedly over 24 hours.
Ordering from England (or trying to), messaged Martin on the M4D M4X Site page.
Will try again tomorrow!
Cheers,
S-L
@teacher,
Cheers,
S-L
Keep trying, it finally worked for me on the 3rd or 4th try. :+1:
Hello my dear friends!
new in my dealslist:
(click here to get price and code)
Lumintop Zoom1
850 Lumen 5Modes + Zoomable USB Rechargeable 18650 LED Flashlight
Amutorch TC500
Luminus SST40 / PhilipsLuxeon / XP-L HI
5 Modes Waterproof Flashlight 21700 Battery Portable LED Flashlight
Weltool M7 just USD35.-
X-LED 353LM 2 Modes Inspection Flashlight
IP67 Waterproof Mini Handheld Even-Beam Torch
@teacher, Yes, same message repeatedly over 24 hours. Ordering from England (or trying to), messaged Martin on the M4D M4X Site page. Will try again tomorrow! Cheers, S-L
try early in the morning !
i tested today 8am and 10 am and it worked
now (3 PM its gone)
Any good deals on
Astrolux S41S COLORED
or ” Astrolux S42S COLORED”:https://www.banggood.com/Astrolux-S42S-Colored-4xNichia-219CXP-G2XP-G3-2023LM-Rechargeable-Mini-LED-Flashlight-p-1151523.html
and 1x18350 battery
please
banggood created a collection for the most wanted items paired with a nice discount:
also they added some additional promotions and deals for you!
just click the picture above and start browsing thru the page!
Thanks Martin L2 for 21 $ is hard to resist
Where did you find the L2 available for $ 21? I can only find it for approx. $ 28 when I deduct those 32%.
