I have four of the 2700K sst-20 in a custom built Convoy M2 Quad. Itās an awesome light. Lovely color, and very good color consistency, better then my R9050 2700K 219C. Expect a color warmer then the 219C as that emitter tends to hit 2850K while the sst-20 delivers a more of a 2700K, solidly hitting the mark. Color temperature across the beam is better and more uniform then the 219C.
Iām also working on a 3000K sst-20 light, and it also delivers a solid color temperature of 3000K. I really like the sst-20 range so far, it isnāt like Cree or Nichia that tend to be off with their warm white CCT. I hate the newer flip-chip Creeās. Thier XP-E2 2700K fails to hit the mark metering around 3000K in frosted TIR optics. Without the TIR, itās a Cree rainbow with the hotspot hitting 3100K+ and the yellowish rings hitting the 2900K range. Their 3000K models tend to show similar upwards bias.
I donāt know as much about the XP-G2 series, but I would probably avoid the XP-G3 in the warmer tint bins. I tested what was sold as some ANSI White 8B/2800K emitter that was very much over 3000K. It looked like they tried to play some sort of visual trickery to make the CCT appear warmer then what it was but failed. It had this unnatural rose/reddish tint, and poor color consistency across the beam. It did not play well the the orange peel reflector.
Iād like to get another chance at the S2+ Copper. I only bought my first S2+ from FT in Jan. They havenāt arrived yet (hit customs this morning) I saw the copper ones, but I had also gone a little haywire with spending on a new Leatherman Charge+, 2) BLF A6s, another budget flipper knife (Eafengrow EF66), Ti toothpicks and a bunch of other random things.
So, yeah, reading and following othersā suggestions for updatesā¦ Smooth body w/18350, triple Nichia 219, stainless switch cover and A6 driver. Too much to ask from a newbie?
You could build yourself one just like that, minus the copper part, all the parts are readily available and fairly cheap. Grab a host on Convoyās AliExpress page. All the cool new colors are there, or you can take some oven cleaner to the light and strip off all the anodizing and have a raw aluminum custom light you built yourself. Super easy. If you get stuck on anything somebody is always here to help you out.
Built a torch with one of his blue lighted switches in the past. Used 5.1Kā¦ + 10Kā¦ bleeding resistors (ā3.37Kā¦), it ended up being @#$% bright. I'd probably choose 10Kā¦ next time.
Simon what tint and flux bin did you get for the 2700k? Because the tint on the sst20 is is very output dependent, green on low output amd rosier on high output, Iām hoping you g9t the JA1,JA4,JD1,JD4 tint bins because with those at least the tint will not be green/yellow at low outputs. But regardless sst20 is less green than any 219C.
^ Despite all efforts by BLF-members and sellers to get special colour bins below the BBL for the SST-20, it seems that Luminus, for all colour temperatures delivers the same limited set of tint bins that are generally a bit above the BBL , and is only below the BBL for the 3000K version. I doubt that Simon will get a different tint bin for 2700K than Kaidomain (which is the JC1 bin).
Lighted tails the way that was developed on BLF using bleeding current from batt+ to the tail (which was used in a few BLF and Astrolux lights) are an electronic can of worms, all resistor values must be tuned to not not disturb the user interface, any change in the flashlight, even a different main led or a different tail colour requires renewed tuning of the values. Some types of drivers will not even work with a lighted tail. I do not recommend manufacturers to add a lighted tail on their flashlights unless they really know what they are doing.
