【convoy】H4 and B35AM options are updated
Estimate release date for the ramp version?
oh ,i see :smiley: ,driver still needs half a month, :person_facepalming:
I add link of SST20 here
Could you mention the flux bin, colour bin and voltage bin of the SST-20 leds? (i.e. a picture of the package label will show that)
Good price btw when 5 pieces are bought! :slight_smile:
That's ok, I've just seen it on the first page and I though it was already available.
Simon could you add XHP50.2 K2 3C option for S11 and only led +MCPCB
That’s great, thanks!
Another question: Will the boost-driver of the S11 have mode-memory, and if so, can it be disabled?
ok i updated the description
what about 3A 3D? i will add link later
yes ,it has memory,
so do you want to enter into moonlight directly?
For small lights, I like start in moonlight since I use my flashlights in the middle of the night and dont want a blinding light. It would be good if theres an option to enable or disable moonlight mode like in the Reylights.
I like the simple UI of some of the Olights - from off, hold button to enter moonlight mode, a normal press goes to memory, and double press to turbo. When on, holding cycles through L/M/H (or ramping, either or).
Nice and simple, then throw all the config stuff up the top.
Thanks, that helps :+1: Bought a few 5000K SST-20’s on 16mm boards!
Amen to that :) My favorite UI so far would be the Sofirn C8F, pretty much similar to the olights, at least in ramping mode which is the only mode I'm using on it since I've got it as it's the most intuitive one, the one mode that made the most sense to me. I have the tail click with mechanical on/off (still has the memory of the last used mode) then the side e-switch click for on/off, hold for ramping, hold from off to moonlight, double click from on/off to turbo and triple click from on/off to strobe (which I could very much do without.. I'd rather have a beacon mode instead of any other disco mode on a light)
It’s what’s stopped me from buying a bunch of different lights - priority one is emitter temp, priority two is UI. I can’t reconcile the Zebralight UI or I’d consider one :frowning:
So hopefully the S11 is nice and simple, and we can all enjoy a nice 26650 that just works how it should!
Simon, do you have pictures or artist impressions of the upcoming ‘S2+ 21700’? Want to see!! :smiley: :smiley:
the same appearance as S2+ 18650 ,just a little thicker
about 25.5mm diameter
Is this also the new S2+ and S2+ 21700 design Simon?
Hello Simon,
A few months earlier I mentioned, that I would happily buy a certain variant of Convoy C8+ (probably repeatedly if I can get some interest locally for it).
Can I tell my wish about it regarding the details?
I would be interested in a C8+, which is:
- Clear anodized
- Has the traditional tail cap, but it has translucent button
- Has support for 21700 battery
  • Driver support is also traditional (but if it is larger, no problem - just please keep 17mm driver support as well)
