- This content originally appeared at zeroair.org. Please visit there for the best experience!
- Didn't really know where else to put an "internal cell" light.... technically it's a lipo, but that doesn't fit the specifics of this sub. But even less so the others!
- Thank you for reading!
I reviewed a few lights for RovyVon, and one of those was the E300S. That light has Cree XP-G3, one of my least favorite current emitters, and after the input from my review (and letâs be humble, probably other sources), RovyVon released a Nichia option! This review is largely the same as that original, with the main difference being the emitters.
Official Specs and Features
Hereâs a link to the official product page.
Versions
There are a few versions of this light. First is the aforementioned emitter choices â Cree XP-G3 and Nichia 219c. And there are two body colors too. Black, seen here, and a titanium gray body.
Price
These lights are currently $82.95
Short Review
I liked the original E300S âŚ. but I actually did an emitter swap on it to put inâŚ. Nichia 219c. So I sort of feel like Iâve had this light before (even though I gave that one away!). This is a fun light, and the Nichia is really an upgrade. There are a few things that could be improved â the pocket clip, for example. Also the light is a bit large for this style, but thatâs understandable.
Long Review
Whatâs Included
- RovyVon E300S
- Paracord
- Pocket clip
- Manual
Package and Manual
The package on this version is decidedly different â I had a pre-production model before. The package for this light is well done, and nicely printed.
The manual is a two sided A4 paper with all the info you need about the light. Unfortunately the manual hasnât been updated to reflect the lower output that Nichia provides. So be aware that the numbers on the manual (and also on the bezel of the light itself) are not accurate for the Nichia version.
Build Quality and Disassembly
This light has a very interesting and unusual look. Almost any other light I can think of in this format a) isnât a triple and b) isnât a right angle light. Thatâs neither good nor bad, but it does make this light stand out.
The build quality feels good. As I said in the intro, the light is quite big for what it is and what I was expecting, and thatâs reflected in how it sits in the hand.
Thereâs plenty of texture on the body, but none of it is particularly grippy. The light is well made, in any case.
Two torx screws hold the body together. Yes just two! Theyâre on the head end of the light, and once removed allow the light to slide apart.
Here are a bunch of disassembly pics!! These are from the original review, but the internals should be exactly the same. Just disregard the XP-G3 emitters in the pics below!
Probably a temperature sensor there â normally in contact with the brass⌠thing⌠â Iâve lifted it for this pic. Thatâs just thermal paste, not glue or anything permanent.
Now look at this!!
Thatâs a heatsink with liquid! Oil, of course.
Really though, to get into the light, one must remove the bezel. Itâs not easy; I finally just used pliers and grabbed the edges. Surprisingly didnât really damage it, though! Youâll need access to the back (more or less), to keep the back bits in place for the removal of the bezel.
Once the bezel is out, and the three Torx (T6) screws are out of the pcb, parts start coming out!
The battery (confirmed 2200mAh).
The optic:
Hereâs all the screws required to get things completely apart. Two Torx T6 on the outside, three on the inside:
Hereâs the whole emitter/cooling all in one. This is as closed as I can get the liquid cooling now â it was probably installed under vacuum or something, to keep air out. With that in mind, I recommend that you donât remove the brass cover. Better left closed.
There are two holes into the (non liquid part) of this container. Theyâre for the leads. I broke a lead when unscrewing â learn from my mistake. Donât twist on this too hard! Should be an easy fix, though.
The mcpcb is thermal pasted down, but not glued. Easily removable â Iâll swap out these XP-G3âs asap.
Charge port and the leds beside it.
Side switch:
Size and Comps
Dimensions: L 101mm x W 36.7mm x H 17.3mm. The weight is around 95g, or 105g with clip.
Here is where youâll probably recognize that this isnât a small light. On the thin side, itâs almost as thick as the Convoy S2+. And much too close in length, too.
Retention and Carry
A pocket clip is included. Itâs the same style as other RovyVon lights, with the clip basically friction fitting around the sides â a hugger clip, if you will. Itâs different from many friction clips though, in that it can be positioned just about anywhere up and down the body of the light, front or back. That gives quite a few options, for very precise placement.
Unfortunately my clip doesnât fit on the body of the light right. Itâs like the arms are just a shade too short, so (as you can see below), the clip doesnât grab the body fully.
Then thereâs the built in loop on the tail end of the light. This could be used any number of ways, primarily with the included paracord. This is a good option, and while other parts of the light have sharp edges, this part doesnât â it should give the paracord a long life.
There are no magnets. A big fat (ok âthinâ) magnet right in the center of the internals, where the light could face outward would be a no-brainer for this light.
Power and Runtime
Thereâs a built in battery for the E300S. No mention is made of replacing it, and no other power source can be used. So this light necessarily (like all internal cell lights) has a limited (probably reasonably long, of course) lifespan. The claim of the internal battery is 2200mAh.
The claim of 1200 lumens is confirmed in my testing. At 30 seconds I measure over 1200 lumens. This is why the light ends up being so big â to get those big numbers, there needs to be adequate heat management, and a big capable battery. Output steps down fairly hard at around 1 minute, and then just drifts downward until the side switch begins warning the user that the cell is depleted.
High looks about the same, and also has a noticeable stepdown, this time a little bit later. After that, the graph looks about the same as with Turbo, but at a lower output.
With the internal battery comes built in charging. Thereâs a micro-USB port on the side, plugged with a rubber cover just like on the Aurora series. (A spare cover is included.) Beside this port is a charge indicator.
RovyVon includes a USB to micro-USB cable, too.
They also include a spare cover for the charge port. I always thought âwhyâ do makers include this. Well when I was unplugging the charge cable one time, I accidentally grabbed the cover without knowning it, and jerked it right in half. Not just out, but actually broke it! So Iâm glad to have a spare!!
Charging looks quite good, and is surprisingly over 2A to the cell. Thatâs probably not too much for the small cell, since the output at Turbo is likely draining it at a much higher C. Charging is quick, at just under an hour and a half (!!). The indicating switch turns solid blue when charge is complete.
Why are there two vastly different charge graphs there you may ask? Good question! The higher current graph is from a QC3 port. Itâs not using QC3, but the port has high current capabilities. The lower charge rate is from another, less capable setup. So the E300S will make use of good charge ports!! Useâm if you gotâem.
PWM
For reference, hereâs a baseline shot, with all the room lights off and almost nothing hitting the sensor.
Looking at the graphs below you may say âwow PWM all the way to turbo???â Yes, but no. Look at the scale: 50us. Thatâs MUCH faster than anyone will ever be able to see. This is as close to âgood pwmâ as Iâll ever agree. Itâs completely unnoticeable.
User Interface and Operation
There are two switches on the E300S. The main one Iâve used is the side switch. The âpower switchâ is on the top (and labeled with a power symbol).
They are both e-switches with rubber covers, and identical in size. Actually⌠both are labeled with a power symbol! Clearly the same cover. And they both have the ability to turn the light off, so thatâs reasonable. (Also note in the picture below since I donât think it shows elsewhere, how much the bezel sticks out from the body.)
H
ereâs a UI table!
State | Action | Result |
Off | Click Side Switch (SS) | No action |
Off | Click Top Switch (TS) | No action |
Off | Hold SS | Moonlight |
Off | Hold TS | Momentary Turbo |
Off | Double Click TS | Strobe |
Strobe Group | Click TS | Strobe advance (Strobe>SOS>Signal) |
On | Hold either switch | Off |
Moonlight | Click SS | Mode Advance (LMHTL) (Moonlight not in mode cycle) |
Off | Double Click SS | 250 Lumen output (not âLowâ or âMediumâ) |
From 250lm Output | Hold SS | Infinite Variable output (fast ramp up and down) |
Off | Triple Click SS | Medium â 450lm |
Thereâs a chance I missed something in the UI. Itâs fairly robust, but thereâs a little overlap between the switches. The ramping is neat, but doesnât blink or anything at the bookends â so itâs hard to get âexactlyâ low or âexactlyâ high (which are 60 and 1600, respectively, for the variable mode).
LED and Beam
Big ol thanks to RovyVon for putting Nichia emitters in this light. I like a responsive company, and RovyVon certainly seems to be that!
These beamshots are always with the following settings: f8, ISO100, 0.3s shutter, and manual 5000K exposure.
I might be willing to say the turbo pushes these emitters close to the edge, because I pick up a little pink in that turbo beamshot.
You may find yourself wondering how that compares to the emitter swapped version I myself made? Well I can answer that too. I edited that post before I gave away the light, to include beamshots with Nichia, on that light. See here. Very similar indeed!
Tint vs BLF-348 (Killzone 219b version)
I compare everything to the Killzone 219b BLF-348, because itâs inexpensive and has the best tint!
The Big Table
RovyVon E300S | |
Emitter: | Nichia 219C |
Cell: | Internal |
Runtime | Chargetime |
LVP? | Switch warning (red), and very low output |
Power off Charge Port with no Cell? | â |
Claimed Lumens (lm) | 1200 |
Measured Lumens (at 30s) | 1239 (103.3% of claim)* |
Claimed Throw (m) | â |
Throw (Calculated) (m) | 149.1 |
Candela (Calculated) in cd (at 30s) | 322lux @ 4.155m = 5559cd |
All my RovyVon reviews! |
* Standard measurement disclaimer: I am an amateur flashlight reviewer. I donât have $10,000 or even $1,000 worth of testing equipment. I test output and such in PVC tubes!! Please consider claims within 10% of what I measure to be perfectly reasonable (accurate, even).
Conclusion
What I like
- I like the novel idea of this style light
- Build quality seems good
- Charging is excellent, at over 2A
- The UI has something for everyone!
- Love that itâs Nichia!!
What I donât like
- Overall, this light is too bulky
Notes
- This light was provided by RovyVon for review. I was not paid to write this review.
- Whether or not I have a coupon for this light, I do have a bunch of coupons!! Have a look at my spreadsheet for those coupons. Itâs possible to subscribe and get notifications when the sheet is edited!!
